CUBE U30GT 2 Mobile dongle ?
scotslad
Forum Posts: 92
Thanks Received: 5
2013/07/05 - 03:11
It is recommended to use one of these from the tablet manufacturer according to the chinese shop I bought my tablet from, this is what they recommend, one of these models >>>>
  3G Not built in, support external 3G dongle: E1916, ZTE AC2736, HUAWEI E1750, HUAWEI EC122, HUAWEI EM770W
Cube U30GT2
Android 4.2.2
Custom root firmware final 2.04 version
scotslad
Forum Posts: 92
Thanks Received: 5
2013/07/05 - 03:42
I was advised that it may be better to stick with the Huawei E1750 Model as its "meant" to be one that does work on the UK mobile networks (thats if you want to use it in the uk I mean).
Theres and example here, but there is loads on ebay etc >>>  http://www.ebay.co.uk/itm/Huawei-E1750-fastest-3G-USB-mobile-broadband-dongle-modem-stick-UNLOCKED-Android-/140953699809?pt=UK_Computing_Mobile_Broadband_Devices&hash=item20d17ec5e1
Has anyone tried a mobile dongle to get 3G yet with the CUBE U30GT 2 that is tried and tested working ?
Maybe this thread should be made a sticky or a sticky made just like this for the CUBE U30GT 2 (3G) dongles as I'm sure people are very unsure, just the same as I am unsure too, know what I mean ?
It would also be good if you could post up the exact make and model number of the 3G mobile dongle that you have tried and tested obviously, without that info we wont know, lol.
Its just that some of these dongles simply either will or wont work with certain devices because of the drivers etc, so I'm not sure if maybe only the ones I listed will be the only ones that will work, or if its defo only the Huawei E1750 for use in the UK, I have no idea, but I would like to buy a dongle and have it spare incase I ever need it, so it would be very very handy to know what models have defo been tried and tested.
As long as they are unlocked I dont think it matters what mobile provider sim card you put in it, for me it would personally maybe be O2, or Vodafone as I get a good signal with them in my area, but on the whole I dont think it matters as long as you check the coverage of the provider you are going to use.
Anyway, maybe we can start to find out what works and what doesnt eh ? good idea or what ?
Cube U30GT2
Android 4.2.2
cuberiordan
Forum Posts: 60
Thanks Received: 17
2013/07/05 - 09:00
I have a huawei e586, from o2, and it works perfectly, I mainly use my galaxy s3 as a portable WiFi hotspot, it it works like a dream.... Unlimited data from three :)
scotslad
Forum Posts: 92
Thanks Received: 5
2013/07/05 - 11:09
thanks mate for your input, but I only want to know about the ones that are tried and tested working on the CUBE U30GT 2, not any other device as they all differ, thanks all the same though mate.
Cube U30GT2
Android 4.2.2
cuberiordan
Forum Posts: 60
Thanks Received: 17
2013/07/05 - 12:05
U misunderstand i use the e586 on my cube u30gt2, and i also use the internet from my phone on the u30gt2, i tether the internet on my phone thereby making my phone a router that can be used with my u30gt2
scotslad
Forum Posts: 92
Thanks Received: 5
2013/07/06 - 07:01
I was just wanting a dongle that I could use straight into the CUBE U30GT 2 without tethering with the mobile phone etc, I know what you mean, but I am looking just to buy a dongle that I can plug straight into the CUBE U30GT 2 obviously I will need to use the micro usb to female usb adaptor cable to do this too, but thats ok, they are only pennies from ebay.
Are you saying your dongle will defo do the job for me the way I want it like straight into the machine mate ? Please let me know. (its not so much for me but for the wife, so the less hassle the better, you know what I'm saying ?).
p.s
I would imagine too that if its an O2 dongle then the giffgaff gigabag simcard will work fine in it too as giffgaff use the O2 transmitters and its an O2 top up voucher you buy to top up the card or you can use your credit card to top up too etc, giffgaff is basically running on the O2 network is what I am saying.
The thing that worried me with these dongles is that they can be tempramental with thier drivers etc, you know, like if the place recommends a certain model or models then maybe the reason for that is because of the drivers, its hard for me to say, but I know in the past I have ran into problems with dongles and drivers etc etc, plus the fact I dont want to fork out ÂŁ15 to ÂŁ30 etc and then have a problem, thats a nightmare if that happens, know what I mean ?
Cube U30GT2
Android 4.2.2
cuberiordan
Forum Posts: 60
Thanks Received: 17
2013/07/06 - 09:10
Hey man, the one I from o2 is not one u plug into the machine its just one you carry around and u connect  to it like any normal WiFi connection, I think the ones u plug in are too much hassle.
I'm from Ireland so we don't have giffgaff over here, but the dongle takes normal sim cards but u may find that its blocked to only accept o2 sims, I never tried putting another sim in, all I have are micro sims, hope this clears things up
The following users say thank you to cuberiordan for this useful post:
scotslad
scotslad
Forum Posts: 92
Thanks Received: 5
2013/07/06 - 18:07
@ cuberiordan, ok mate, I understand (i think, lol), thanks mate.
Does anyone else have anything to add about which "normal type" dongle should work 100% tried and tested with the CUBE U30GT 2 ?
I still think this thread should be made a "highlighted sticky thread" on the website as there is no other thread to tell us what dongle 100% works, you know what I mean ? Its not just for my benefit to make the thread a "sticky", its for everyones benefit, cheers :)
(plus the fact the thread will then get noticed more and people will give it more attention as right now there is only myself and cuberiordan even bothered posting in here).
Cube U30GT2
Android 4.2.2
scotslad
Forum Posts: 92
Thanks Received: 5
2013/07/21 - 05:02
according to one user so far he has said that >
GPS dongle BU-353  S/N:BUG0154158 does not work on the CUBE U30GT 2 but maybe it might need the correct drivers, none-the-less he said it does not work, so this is a starting point, thank you user "sloed" for the info :).
Please other people keep info coming in, especially if we can find ones that do work, even better :) , and I am talking about normal usb mobile dongles, nothing else really.
I still have not had any reports on the ones recommended by the manufacturer of the tablet yet, but I dont trust them (the tablet makers, why should I because of all the issues they have had with the tablet letalone anything else) because of the issues they have with their tablet then why should we trust their recommended dongles even though it isnt them that makes them ?
so its really handy for everyone to post any dongle that works 100% on the CUBE U30GT 2 so that we all know, thank you please :)
Cube U30GT2
Android 4.2.2
Uznamer
Poland
Forum Posts: 42
Thanks Received: 12
2013/07/22 - 21:35
I am using Huawei E3131 on my Cube U30GT2 as a GSM dongle and it works perfectly. Anyway  I am not sure if my info would help you as I am a Polish guy and living in Poland. Therefore I cannot know if the same device would work in UK. We have four different GSM operators here but my dongle has no sim card and it can work with any of them.
The following users say thank you to Uznamer for this useful post:
scotslad
scotslad
Forum Posts: 92
Thanks Received: 5
2013/07/23 - 06:58
scotslad said
Please other people keep info coming in, especially if we can find ones that do work, even better , and I am talking about normal usb mobile dongles, nothing else really.
_____________________________________
thanks mate, people, please keep your info on usb mobile working 100% dongles coming please, thanks :)
Cube U30GT2
Android 4.2.2
scotslad
Forum Posts: 92
Thanks Received: 5
2013/07/23 - 07:30
______________________________________
Uznamer, is that just a normal usb mobile dongle, yes ?
doesnt matter what country your in mate as long as its the Cube U30GT2 you have it plugged into ?
cheers mate and thanks for letting us know :)
Cube U30GT2
Android 4.2.2
Uznamer
Poland
Forum Posts: 42
Thanks Received: 12
2013/07/23 - 09:00
@Scotslad. Yes. I do confirm it is a normal usb mobile dongle and it is working smoothly.Laugh
scotslad, oldpal
93 Guest(s)
Devices in use: Desktop (84), Phone (9)
Morris028
robertgdfdgdfss
wtf
jdani20001027
thinkappleeight
dubsiki
