2013/04/01
CFW Vondroid Cube U30GT2 1.x 1.0
Based on OFW 2.06 with following changes:
- 4GB Internal Storage
- CWM Recovery (ClockWorkMod)
- Rooted
- Debloated Chinese Software
- Add apps (Youtube, ES File Explorer)
- Apps updated
- Ads block
- Partial Build.prop optimise
just updated to v1.1:
Update v1.1:
- Solved Settings crash issue
- Fully Build.prop optimise
- Fully market support
- Init.d support
- Init.d tweaks
- Update apps (GoogleSearch)
- General system optimise (Launcher.apk, Framework-res.apk)
- Vondroid Boot animation
- Support extra .ko files (Tun.ko, cifs.ko, nls,...)
http://vondroid.com/resources/cfw-vondroid-cube-u30gt2-1-x.374/
The following users say thank you to leeyuentuen for this useful post:
maikal
2013/04/01
I want to test this Rom. Is It in CWM zip format available and what Init.d and build.prop tweaks you've done? Is It Overclocked?
No it is not a cwm build. You need to flash with rockchip batchtool
init. Has use to improve system reaction but not overclock(need to be in kernel)
build.prop edit to improve battery and some screen smooth
2013/04/01
DarthJabba said
@leeyuentuen - you might want to provide it in CWM format if you want people to try it. As has been said by others, it is too much hassle to go through the batchtool, just to try out a ROM.
I'll take a look for a CWM
but there are already few extra updates:
Update v1.2:
- Use Google Gallery to sync with Gmail Photos
- Init.d Vondroid script update + sysctl
Update v1.3
- Remove default launcher and replaced by Apex Launcher
- Add init.d script (disable radio tnx to @affs )
- System to ext4
- Reduced system.img size
Update v1.4
- Fix Disable Radio signal (see screenshot) tnx to @affs
- Init.d Vondroid script updated
- Update SuperSu
- Fix missing Ko files (Slow-work.ko, nfs.ko)
2013/04/26
2013/08/28
leeyuentuen said
DarthJabba said
@leeyuentuen - you might want to provide it in CWM format if you want people to try it. As has been said by others, it is too much hassle to go through the batchtool, just to try out a ROM.I'll take a look for a CWM
Update v1.2:
Update v1.3
- System to ext4
Update v1.4
- Update SuperSu
The rom really sounds good and interesting. May I just ask a silly question, can it play “Crazy Taxi”?
I tried almost all original and custom roms before, but no one play it flawlessly. I don’t know why the motion control never worked in the game. Since my girl loves the game so much, I am so longing for one rom that works.
57 Guest(s)
