Just untick and tick the boxes like shown in the pic.
2015/06/19
Okey,and that´s all?,I gonna test it now,are you online a Little while if it not work?
After this flash the TWRP recovery with AndroidTool
a) go to app drawer, open RebootMenue and "Reboot Bootloader"
b) untick uboot, ressource, kernel, boot, recovery, system
c) tick TWRP
d) click Run
e) tab boots into TWRP
f) reboot system
but now whén I gonna flash the twrp,do I have to restart the tab Before that?
was it reset and Power at same then to make it restart?
It should be started into TWRP.
Did you flash the build before, incl. LowerFormat?
So, the build was not running before? Start with instructions 3).
2015/06/19
You mean this: 3) flash the firmware with AndroidTool
a) run AndroidTool.exe with admin rights
b) press Reset and then immediately press Power off and Vol up > status "Found One Loader Device"
c) click Lower Format
d) click Run
e) stock recovery will format the NAND
f) wait 4 min
I have done all that if that is build 🙂
Ok, and you saw Android booting? And found the RebootMenue app?
2015/06/19
no mate,it won´t start at all,first this (i will add Pictures)
d) click Run
f) wait 4 min
and then restart it?
Yes, after this it should boot into Android.
Is your tab really U25GT-W4 or is it U25GT-C4Y?
On the back of the tab or on the box.
Ok, rigth firmware for the tab.
Go on with the flash procedure. After LowerFormat click Run now.
85 Guest(s)
Devices in use: Desktop (77), Phone (8)
cutierogue
hans41
rickybk
