2013/05/11
Hi
I explain you the situation:
In my livingroom there is my ADSL box (Freeobx V5 )
In my bedroom, i've got a PC with a Wifi card and a bluetooth card, but it doesn't see the Wifi network, it is that why my PC is connected to the web through CPL.
My goal: i would like to use my PC to connect my cube to the web when i am in my bedroom.
Then:
1/ Solution 1: Can i connect my Cube to my PC through Wifi creating a local wifi network in my bedroom to access the web?
If yes, How can i do it?
And which softs i have to use on the PC and Cube sides?
2/ Solution 2: Can i cionnect my Cube to the PC to access the web through Bluetooth?
If yes, How can i do it?And which softs i have to use on the PC and Cube sides?
Thanks in advance for you answers.
Regards
If your network card/ OS is supporting you can create a local network
Check for this, it will give you more guidance
http://lifehacker.com/5369381/turn-your-windows-7-pc-into-a-wireless-hotspot
This solution works only with Windows Vista/7/8
You can use some software solution which will basically to the same thing, use your wifi to create an AP
After you create the AP, you need to bridge your 2 networks (the one from which you have the internet and the AP)
82 Guest(s)
Devices in use: Desktop (70), Phone (11), Tablet (1)
olegator
Ur
beelink
TheMentor
smalec
marek.test@gmail.com
