2013/08/02
hello all again
have been trying to flash this ware and, and while I've studiously followed the instuctions, it doesn't seem to be seen by the batch tool. My PC has recognised it, to the point where it even has correctly identified it. However, the batch tool doesn't seem to pick it up...also what is the difference between cwm_rooted4 and rooted4?
What is cwm
http://lmgtfy.com/?q=what+is+cwm
maikal
2013/07/09
globula_neagra said
What is cwm
So we can install CWM ourselves without it having to be part of the current rom we flashed or do you advice against it with the current rom? Newb here, just FYIing myself. What about cyamodgen, would you advice against it? Your thoughts, if time permits on cwm v. cyadmodgen? Or anyone else who might wander by and want to answer!
Yes, you can install it yourself if you know how.
Cyanogenmod is not available for 30GT2
And it seems that you did not understood what is CWM whichs stand for CLOCKWORK MOD RECOVERY
STOCK RECOVERY
-no options in backing up your tablet
-you are able to flash only the content that is released by the producer
CWM
-various options in backing up your tablet
-able to flash different zip packages released by different devs
maikal
2013/07/09
Yes, you can install it yourself if you know how. Cyanogenmod is not available for 30GT2 And it seems that you did not understood what is CWM whichs stand for CLOCKWORK MOD RECOVERY STOCK RECOVERY -no options in backing up your tablet -you are able to flash only the content that is released by the producer CWM -various options in backing up your tablet -able to flash different zip packages released by different devs
My pardon. I did understand, and I don't have the CWM version installed. I was just wondering for my own personal knowledge.
2013/08/02
hello all again
86 Guest(s)
Devices in use: Desktop (75), Phone (11)
PATRYK-VP
victorialp23
alertscam
aolmail7448
Arc123456789
forty42
