App Install not working/factory reset not working
fakethislife
2015/01/02 - 14:58
I have a Cube U30GT2 that I recently had to do a factory reset on. Since the reset no apps will install and I tried to factory reset it again but it doesn't do anything. I've not deleted anything from the tablet, I've updated everything apps wise, I've turned it off and on again, I've tried the problem shooting mode (Volume+ and Power I'm hopeless at remembering the names of things) I've even tried updating the firmware but it fails with the error 'no drive found' before doing anything.
I don't know what else to do? The Chinese bloat ware does my head in, I already played a game that came on the tablet, but I can't update it because something doesn't match.
I only did the reset as the darned thing was running so slow I couldn't do anything (virus checked it, malware and spyware checked, uninstalled apps, off and on again etc)
Any help please?
Mark06
Forum Posts: 222
Thanks Received: 41
2015/01/02 - 16:04
Maybe the time setting is wrong. Try correcting it. You have to install the rockbatch drivers for the computer to recognize it.
fakethislife
Cube u30gt2 tab
fakethislife
2015/01/02 - 17:46
I've gone through the device drivers in the device manager, and they're installed (or so windows is telling me). I've run the rockchip batch tool, and that keeps giving me a not supported error - I've attached a screen shot.
Why you say time settings, do you mean have it at my time (GMT) or have it at the Chinese time it came set to?
rockchipbatcherror.pngImage Enlarger
Mark06
Forum Posts: 222
Thanks Received: 41
2015/01/02 - 18:15
Push the switch button. Local time yes.
Cube u30gt2 tab
fakethislife
2015/01/03 - 15:19
Thanks for your help, managed to upgade it on a different computer, all worked perfectly.
76 Guest(s)
Devices in use: Desktop (70), Phone (6)
hans41
rickybk
soniya07
ironmangitar
