Android L 5.0 - Can we port it?
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
46
2015/06/03 - 02:36
Has anyone gone there? I'm going to go see now. I'll report back.
I managed to download the .rar files, but the first one was corrupted and it did not open all the way. I will try on another pc tomorrow.
airman
Milano
Forum Posts: 33
Thanks Received: 5
47
2015/06/03 - 20:59
It is surely a fake. Each part is 50 Mb (150 Mb for a Lollipop image, are you joking?) and you need to provide mobile number or email to download.
Dig it.
maikal
Forum Posts: 394
Thanks Received: 51
48
2015/06/03 - 21:19
Saw that. Nothing ventured, nothing gained eh. Besides I got to test the limits of raunchiness and vulgarity when making up fake information and email addresses. ..lol. They will pretty much take anything thrown in the info boxes...lol
aurel.14
49
2015/06/20 - 10:17
Hy,
After lot of difficulties to install this room, i got it !
But i'have a problem with all application with movie (youtube, movie player, TV) : there is no image.
Thx for your work
Edit : I think is because HW acc isn't supported but is strange for youtube and tv ... ?
Positive of this rom : Sound is higher and Brightness is better
stathis1985
Forum Posts: 15
Thanks Received: 6
50
2015/06/26 - 11:12
Can we still have hope for any Cyanogen ROM??
I was doing a quick search in Google for RK3188 tablets and I saw this Video on YouTube.
RK3188 can support CM12.
Edit:
Just take a look at 0:29 the model of the cpu.
stathis1985
Forum Posts: 15
Thanks Received: 6
51
2015/09/14 - 16:12
Edit:
Anyone??
Mark06
Forum Posts: 222
Thanks Received: 41
52
2015/09/14 - 17:50
it's not that you can just flash the cyanogenmod 12.1, guess the ones you can download are like .tar or .zip. So if you want to flash it, you might be able to do that by clockworkmod, by loading the zip file. Am not sure, could it be the kernel is containing info about the cpu and gpu. Then it might be possible to flash the zip file in cwm, then connect the tab to the pc and flash the jellybean kernel for the rockchip 3188. That's if the difference is only in the kernel.
be carefull i guess, maybe someone can add some info.
Cube u30gt2 tab
53
2015/09/15 - 21:00
For all the forgotten tabs 😉
http://crewrktablets.arctablet.com/?p=5577
Mark06
Forum Posts: 222
Thanks Received: 41
54
2015/09/16 - 08:12
Been busy for like an hour flashing the new firmware, doesn't really go smooth, it keeps rebooting. Has been in the language menu one time though. Is there a possibility you guys also make a cyanogenmod 12.1 version of this? Using a overclocked kernel from this download, it at least comes at the boot scroll screen. Guess the battery is empty or something.
Can't get into recovery menu neither using the volume up and power button.
grtz,
Mark-1978
*edit: i get into the choose language menu, then it just reboots. Oma what is wrong?
Cube u30gt2 tab
55
2015/09/16 - 17:23
U30GT2? Use the JB stock kernel. Make sure you are on gen1 loader and flash incl. eraseIDB.
Mark06
Forum Posts: 222
Thanks Received: 41
56
2015/09/16 - 17:58
Oma, i've got the idea that an overclocked kernel doesn't have all the info the stock kernel has, so that means indeed you got to first flash a new firmware with the stock kernel before flashing the overclocked kernel.
edit: it just doesn't seem to work. I do all the things you say, get into the language select menu at start of android operating system. Then after some seconds it just spontaneously reboot the tab. This again and again.
Cube u30gt2 tab
Mark06
Forum Posts: 222
Thanks Received: 41
57
2015/09/17 - 11:44
Anyone got this working on a cube u30gt2?
Mark-1978
Cube u30gt2 tab
maikal
Forum Posts: 394
Thanks Received: 51
58
2015/09/17 - 18:06
Mark-1978
I was going to try it this weekend, but I keep seeing you say it is not working. I have that extra cube to try it on that has not been kitkatted yet. But it wont be until sunday I think.
Mark06
Forum Posts: 222
Thanks Received: 41
59
2015/09/18 - 16:31
Mark-1978
Oma7144 can you take another look at this?
thx
edit: there is an error though. When flashing is completed, reboot and in clockwork menu, when i do a factory reset it gives the error: " Error mounting /sdcard/.android_secure!"  skipping format. Seems it cannot mount sdcard and complete the factory reset.
edit2: somewhere else on this forum i saw that the stock recovery may be usefull. So i'm trying to flash the firmware now without the cwm recovery.
Cube u30gt2 tab
Mark06
Forum Posts: 222
Thanks Received: 41
60
2015/09/21 - 09:15
This version is working on the cube u30gt2.
It works very solid, stable, though kitkat 4.4.2 ( kasty rom june 2014, or chinese 2910 2014) work faster in user interface. Still it has a lot of lollipop options. Video playing works stable, camera (what you see) is rotated to the right, can overclock it using the kernel 38, google app store works, rotate is working through app, battery life for what i can see is very good.
Cube u30gt2 tab
79 Guest(s)
Devices in use: Desktop (68), Phone (10), Tablet (1)
Shincozen
karim78190
mario millan
estelavg
Skyzhay
HorstG
