Android L 5.0 - Can we port it?
Mark06
Forum Posts: 222
Thanks Received: 41
31
2014/12/20 - 14:44
XXX-Man said
There is a parameter file for tabs with other NAND sizes then 16 GB on the blog: http://crewrktablets.arctablet.com/?wpfb_dl=2244
You need to replace it in folder /rockdev and flash again incl. eraseIDB.
I already realized it by myself. Tnx again.
did you get it stable and what did you do?
Cube u30gt2 tab
Mark06
Forum Posts: 222
Thanks Received: 41
32
2014/12/20 - 21:17
Oma7144: Can you port the lollipop update for the cube?
http://forum.xda-developers.com/tmobile-lg-g3/development/rom-resurrection-remix-lpv5-2-0alpha-t2966911
by the end of februar there is coming a new rom for cube u30gt2 5.1
Cube u30gt2 tab
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
33
2014/12/23 - 06:29
So this link is NOT for the Cube? A little confused here! Is the Crews rom ready for prime time or still not stable enough? My recently acquired Cube is on the 10/30/13 Katy 4.2 final. I would like to flash something new and stable. Not sure of last kitkat though.
Mark06
Forum Posts: 222
Thanks Received: 41
34
2014/12/23 - 10:45
lollipop 5.0 for cube u30gt2 is not really stable yet no. You'll have to wait till end of february for that new update. The chinese 4.4.2 firmwares are quite stable. I always put off user experience option, i get the feeling it is more stable that way.
maikal
Cube u30gt2 tab
stathis1985
Forum Posts: 15
Thanks Received: 6
35
2014/12/23 - 10:54
Check the 1st post in this topic. I believe it's the most stable version for our CUBE up to now. I'm using it every day with no lags, problems, wifi issues or anything else.
The following users say thank you to stathis1985 for this useful post:
maikal
jrgalang
Forum Posts: 17
Thanks Received: 6
36
2014/12/25 - 12:36
So I've already got this working, and the 32GB parameter file is better for me (single Internal Storage instead of having 8GB for internal and then the remaining partition marked as "sdcard"). The only issue however is that when I tried to access SU, I got a prompt saying that the binaries aren't installed and manual step is required. So I went ahead and used the Root file from Oma, also tried the TPSparky approach but to no avail. Root checker's stating that I'm not rooted, and even if I update SuperSU to the latest version, it doesn't seem to work.
Any thoughts?
Mark06
Forum Posts: 222
Thanks Received: 41
37
2014/12/25 - 12:50
Any thoughts?
yup, when you install the rom and you have factory reset the rom, you go to reboot then you must put in no twice. So no fixing the su. Then the rom is all ready rooted. Sounds strange but it works.
Cube u30gt2 tab
jrgalang
Forum Posts: 17
Thanks Received: 6
38
2014/12/25 - 13:32
Ha, that's strange indeed. Wait, I'm confused on this one:
"you go to reboot then you must put in no twice. "
On the first prompt after hitting reboot, it states that the ROM may replace the recovery with its original one. Do you mean to also click "No" on that too?
The reason I need root is I'm thinking the rotation can be fixed by a build.prop edit, or by files provided by Oma on the KitKat version of his ROM for U30GT2.
Mark06
Forum Posts: 222
Thanks Received: 41
39
2014/12/25 - 13:38
yup. no twice and the recovery menu is the updated one 6.063 version with which you can also overclock using the JB (4.2) overclock kernels. Thought the rotation will still work after overclocking, but indeed the prop editor will otherways help you out. But it isn't really stable, overclocking gives you a little more speed but when you want to use mail  programms it gets stuck each time telling you to close the mail software. Maybe there will be more compatible email software or otherways we have to wait till februari next year for the android 5.1 updated rom.
jrgalang
Cube u30gt2 tab
jrgalang
Forum Posts: 17
Thanks Received: 6
40
2014/12/25 - 16:06
Thanks. Hitting No on both prompts did the trick. No plans on overclocking as I've fried 2 batteries already with it. Going to live with the homebrew kernel that this one has for now. :)
UPDATE RE: Screen rotation issue - no luck. Already tried tweaking the Model Fix for KK or JB just to see if it will also work to no avail. Also went and tried to replace the sensor files over at the lib folder under system\hw but no luck either. Guess this is something we'll have to wait for.
maikal
Forum Posts: 394
Thanks Received: 51
41
2015/03/11 - 04:27
Thanks stathis, link is not working and I can't find it, can you repost link?
Never mind buddy, lol I found it!
I had that one on my previous tablet. I choose to do a Darth's cwm version instead and for some reason it did not work. I will try it on this replacement tablet.
Mark06
Forum Posts: 222
Thanks Received: 41
42
2015/03/11 - 20:46
yep, twice no, so also the option to fix root, strange but true.
Cube u30gt2 tab
maikal
Forum Posts: 394
Thanks Received: 51
43
2015/04/14 - 04:16
Possibly yes. First test build is alive. However, it is a long way to Tipperary
Oma any advance on this rom, or it's as good as it's going to get. It's still a hell of a tablet!
Mark06
Forum Posts: 222
Thanks Received: 41
44
2015/05/28 - 19:10
maikal said
This link says it's the download of the 5.1 lollipop version for the cube. You have to take a survey though.
Cube u30gt2 tab
45
2015/05/28 - 19:15
Hm, seems to be a fake.
73 Guest(s)
Devices in use: Desktop (64), Phone (9)
Shincozen
karim78190
mario millan
estelavg
Skyzhay
HorstG
