2013/10/29
Hello to all, developers and users.
Up to now my CUBE U30GT2 with the kasty-cube_u30gt2-442-funromstudio_20140606-rooted7c_mu with the DJ Overclocked Kernel kernel-95kitkat_cpu1800_gpu768h_ddr600 is working more than fine. Antutu (v5) score is around 23.000 and the battery can provide more than 3 hours of 3D gaming (in sleep mode with WiFi off and muted sound the drop is less than 1% per hour).
Despite all this and the perfect up to now job of the developers, as far as we can see Android L v5.0 is on the way.
So my question is simple.
Is there any chance to see a firmware for our CUBE tablets?? Can we hope for a miracle??
The following users say thank you to stathis1985 for this useful post:
XXX-Man
Possibly yes. First test build is alive. However, it is a long way to Tipperary
stathis1985, maikal, Wintermute, affs, airman, XXX-ManPer aspera ad astra, we rock the Tablets !
Cube U30GT2 has RK903 wifi. So build will already run on the tab, using the JB kernel
stathis1985Per aspera ad astra, we rock the Tablets !
Link see post #3.
Kernel: http://crewrktablets.arctablet.com/?wpfb_dl=818
As you are running KitKat (gen 2 loader), make sure you change the loader first, otherwise you will brick the tab.
2013/05/25
Just been doing that upgrade thing and i used your kernel and the loader, but it only shows the crew tablets logo. What am i doing wrong here?
Never mind it took 7 minutes instead of 4 to get to the logon screen.
tap 5 times on build in the settings menu to get developer options.
One question, what videoplayer do i need since hw acceleration isn't working yet?
Cube u30gt2 tab
For the moment use VLC Player: https://play.google.com/store/apps/details?id=org.videolan.vlc.betav7neon&hl=de
2013/07/09
Yes. Before changing between JB firmware (gen 1 loader) and KK firmware (gen 2 loader) it is essentiell to change the loader first. Otherwise the specific rknand.ko.ko will brick the tab.
2013/09/03
Yes. Before changing between JB firmware (gen 1 loader) and KK firmware (gen 2 loader) it is essentiell to change the loader first. Otherwise the specific rknand.ko.ko will brick the tab.- Oma -
ok thanks for help
i don't know what i'm doing wrong but have a boot loop on crew rktablets logo
i've changed bootloader to gen 1 with rockchip development tool, then i used rkandroidtool to flash image (loader unticked)
then another time rkandroidtool to flash the right jb kernel.img for cube u30gt2
what i've missed ?
The following users say thank you to mooro20 for this useful post:
Mark06Most Users Ever Online: 803
56 Guest(s)
Devices in use: Desktop (49), Phone (7)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
