Weird screen touches while charging ?!
Topic Rating: 0Topic Rating: 0Topic Rating: 0Topic Rating: 0Topic Rating: 0 Topic Rating: 0 (0 votes)
2013/02/09
23:43
Hi, i have 16gb version of CUBE U30GT and the device is great but when battery goes down and put on charger my screen gets weird and makes from one several touches so it makes the device unusable while charging. any suggestions ?
2013/02/09
23:50
Please donate to support my work
Forum Posts: 1876
Thanks Received: 139
Online
Archos 101 XS
Try a charger with the same amperage and voltage output but from a more reliable producer.
fpopic
2013/02/09
23:55
any hint ? anybody tried with nokia chargers ?
2013/02/10
14:03
Forum Posts: 1876
Online
Archos 101 XS
Hello again,i just said use another charger, if you want to keep it safe, you can try with a charger that has a lower amperage then the stock one, using this method the tablet will charge more longer but it will be safer.
I am using on my Archos 101 Xs, a charger that has a lower amperage but the same voltage, only because the stock one it does not work at all, the tablet is ok, with a battery lifetime of 6-7 hours in youtube/browsing
fpopic
2013/02/19
18:33
It's same to use 2A or 10A charger, tablet only uses what it needs, about 1.1 – 1.5A when charging. Only what really matters is voltage. It MUST BE 12V! But charger change really solves this screen touch problem. I personally use 12V 5A charger.
More Info:
admin: 3685
globula_neagra: 1876
Guest Posters: 36
Members: 74502
Forums: 122
Topics: 2807
Newest Members: Dada75, bryan9426, est1980, febope, a4c, linley
Moderators: HaroldG (117), globula_neagra (1876), exelletor (344)
Administrators: admin (3685)
