2012/11/13
I have U30GT-H and a Samsung Omnia2 (WM 6.5).
Spent several days to get my tab use the phone's internet connection,
but no success at all. (Trying BT to avoid rooting which would be needed for wifi).
Here is what I've already tried (and did NOT work):
1. Bluetooth PAN (comes with WM's Internet sharing) from the phone side, dozen of BT utilities from the tab side.
2. WMWifiRouter 2.0 from the phone side (with BT option), dozen of BT utilities from the tab side.
3. FoxFi Bluetooth DUN from the tab side (maybe silly but tried)
4. PDA Net tablet on both devices
and of course searched forums.
If you have and a working solution for a similar setup or have any idea how to use net through this phone pls advise.
Thx.
2012/11/13
I sent this email to PDA Net support:
I have a Samsung Omnia2 (WM 6.5) phone and an Android4 (ICS) Tablet.
I installed PDA Net on both devices, and cannot make them connect to each other.
The tab version does not offer the WM connection in the configuration,
not at all (no WiFi, or BT DUN).
Is there a solution to connect ?
Pls advise.
Thx,
Their response:
Hi
Currently there is no way to connect the two unfortunately.
Thanks,
June Fabrics PDA Software Support
So be smart, huh?
81 Guest(s)
Devices in use: Desktop (77), Phone (4)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
