2012/10/28
Hello folks, may I ask for such manual how to root this device? I am beginner in this, but I have rooted my phone without problem, but it was according manual how to step by step, I don't know how to root this tablet.
Can someone write step by step manual? or where I can find it?
Even how do I know if I have W or H version? what is the difference between those?
Thank you very much
Some google search should give you this guide which looks a quite OK procedure, or you can use a custom firmware such as the one available in our forum which comes already rooted.
From what I remember (my Cube U30GT-H is broken at the moment) you should know which Cube U30GT version you have by looking in the Settings / About tablet, the full model name should be listed there. The H version is newer and has some minor changes in hardware that make it incompatible with W version.
2012/10/28
Thank you very much,
that is what I found also and the first two steps are impossible for me, I am noob in such things
maybe it is not as hard as it seems.
I am interested for something like this
http://forum.xda-developers.com/showthread.php?t=1592355
or this
http://forum.xda-developers.com/showthread.php?t=1809141
don't know if we can give link to XDA so sorry if it is against the rules of this forum
i don`t think the cube tablets have bootloaders.
Usually the bootloaders are only on qualcomm, samsung, nvidia bassed products.
The guide I mentioned in Post #2 should really help, you'll just need some spend some time understand the terminology and trying to figure things out.
In addition we also have a guide for ADB setup here: http://www.arctablet.com/blog/devices/arnova/adb-and-fastboot-tutorial/
You'll just need to stop when you get "adb devices" command working, as, like globula commented, there is no fastboot on the Cube.
2012/10/28
I will try to do it and then let you know ... but later in November, because I left the tablet home, I am traveling now (business) so don't have it with me. At least I have something to study around
Thank you very much, will return here and write comments, maybe they will help someone like me
here is a bat that does what admin sugested you.
http://www.mediafire.com/?24w9d23r25mogg9
i used to root the 7c g3.
2013/01/03
can anyone confirm that some method of rooting (without data sweep) is valid and fully working for U30GT-H?
Btw. I have found this method http://tabletrepublic.com/forum/opinions-on-teclast-p90hdclast-a10-dual-core/how-root-teclast-a10-dual-core-2491.html using ZhuoDaShi, whixh looks very promising.
Thank you for any help.
Currently Online: vonkarayan, astosenix
75 Guest(s)
Devices in use: Desktop (66), Phone (11)
grielgryel
klaus1255
neverever007
favorit
Альфвоф
kevbez
