Cube U30GT-MINI aka U30GT-M firmware update version 1.03:Â U30GT-MINI_V1.03_20120823.zip
repacked & reuploaded from:Â http://www.51cube.net/ch/DownShow.asp?ID=65
Rooted custom firmware for the CUBE U30GT-MINI:Â kasty-cube_u30gt_mini-41-103-rooted2.zip
(updated 2012/10/04, fixed some boot issues + extended app. space to 1.5 Gb)
Based on default Cube U30GT-H firmware version 1.03, default language set to English, added root & SuperSU 0.95, removed Chinese and unnecessary apps, extended space for applications (/data) to 1.5 Gb.
saiboter, raptorzx3, piccolo08, Bigdog1, noom9999 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
The file supplied in post #1 (kasty-cube_u30gt_mini-41-103-rooted.zip)Â provides root access on the tablet, no need to install any rooting tool. This firmware image should be flashing using Rockchip Batch Tool 1.5.
It should work on the Cube U30GT-MINI, but I can't confirm as I don't have a device myself. I'm relying on users report and I'll try to fix problems that are reported to me.
2012/09/10
Experia said
Black screen and now boot... It`s dead now.. no charge...Â
You cannot kill the cube u30gt. It has download mode build in on the chip.
If the screen is black, you are in recovery mode (or the device is powered off).
Connect your cube with your PC. If You hear the "ding" on your PC, the cube is in recovery and was connected.
Then start the Rockchip_Batch_Tool_v1.5 and flash the new firmware.
I got a bootloop with file from admin, so I used this version to root my cube, but maybe the rooted firmware version above works better for you.
2012/10/02
So the first downloadable file is simply a "cleaned up" v1.03 firmware with English set as default, while NOT being rooted?
i'll most likely buy this tablet, and if all go well, i'll install this firmware.
Rooted firmware seem to be dodgy on this tablet though, and i know some apps require the firmware to be rooted to work properly.
Tablet1: Ainol Novo 7 Elf II 16gb -- Tablet2: Cube U30GT-Mini 16gb -- PMP: Ainol V9000HDA Black 8gb
raptorzx3 said
So the first downloadable file is simply a "cleaned up" v1.03 firmware with English set as default, while NOT being rooted?Â
I have just updated the firmware and the first post link, our cleaned firmware (kasty-cube_u30gt_mini-41-103-rooted2.zip) is rooted and has full write access to /system.
2012/10/02
cool! but peoples reported for the previous version that it brick their U30GT Mini...
by the way, do you know a good place where i can buy this tablet?
i have a problem with Aliexpress where they won't let me pay for anything, even my credit card company (Visa) called me to know if it's really me who tried to purchese stuff there, i said yes, and they authenticated the shop on my card (?) but i still can't purchase...so i'm trying to find a good, reliable and trusted place to buy this tablet, while it's priced at around 130$ (i found places selling it for 150$...too expensive).
I heard good things about this tablet, while i wanted a tablet with 1280x800 resolution, it's fine still with 1024x600. The quality is said to be solid, it have HDMI port, dual cameras, nice performances as well (quad-core Mali-400, while my Elf II have dual-core Mali-400, and the RK3066 is a bit better than the Cortex A9)
Some people probably feel they "bricked" their tablet because, as previously reported, they used Cube's supplied USB cable that seem to cause problem to many.
My latest firmware has been verified to work on a device that I have now, so I can confirm it does work indeed.
I got a Cube U30GT-H from Elijah Tech on Ali Express, I don't know about other resellers, sorry. Still, I'd recommend that you double check before buying to any "unknown" place, it seems there are quite a few shops in China selling these devices and not providing proper support if you need RMA or such.
The Cube U30GT-MINI is really a great device in term of specs and performance, but I'd take care of the buttons (power volume) that doesn't seem of very good quality and I'm not trusting much the power charger as well even if it looks better than the one supplied by my U30GT-H which probably killed it, at at least stopped to boot.
75 Guest(s)
Devices in use: Desktop (70), Phone (3), Tablet (2)
wemiy54158
sidor
houssmen
qarolus
dav512
tgergely2012
