2012/09/24
Dear
Every time I try to restore the firmware on my Cube U30GT I always get the same failure.
No matter the version I use everythinh looks to work fine untille the new firmware has to be installed.
Then it stops around 10% and i get a failure.
In the attachement you see that everthing seems to work untill I get the failure
I've tried with versions 1.05, 1.07, 1.09, 1.10, 1.11 and each time the same happens.
Has someone the sollution?
Greetings
Marc Devaere
Hello Marc,
Usual tips are for these situations: try with another USB good quality cable, from another USB port on your computer, preferably a non USB 3 or a port from the back of your machine if you are using a desktop machine. Ultimately, you can also try to flash from another computer.
70 Guest(s)
Devices in use: Desktop (60), Phone (9), Tablet (1)
hans41
rickybk
soniya07
ironmangitar
