Prolem upgrade with rkbatctools..
dralp
2012/09/26 - 21:14
hi everyone, ı ve got a u30gt.. and tried to upgrade v 1.05 android 4.1.. everything was succesfull, but rkbatchtool has said firmware downloaded failed.. and tablet didnt open.. this is log..
20:12:57 273 Rockchip Batch Tool v1.5.3.0 start run
20:17:22 859 **********Upgrade Start Total<1>**********
20:17:22 875 <Layer 5-1> Test Device Start
20:17:23 140 <Layer 5-1> Test Device Success
20:17:23 171 <Layer 5-1> Check Chip Start
20:17:23 187 <Layer 5-1> Check Chip Success
20:17:23 218 <Layer 5-1> Get FlashInfo Start
20:17:23 234 <LAYER 5-1> INFO:FlashInfo: 0 0 0 1 0 10 10 18 1E 4 5
20:17:23 249 <Layer 5-1> Get FlashInfo Success
20:17:23 280 <Layer 5-1> Prepare IDB Start
20:17:23 280 <LAYER 5-1> INFO:CS(1) (8192MB) (MICRON)
20:17:23 296 <LAYER 5-1> INFO:CS(3) (8192MB) (MICRON)
20:17:23 327 <Layer 5-1> Prepare IDB Success
20:17:23 343 <Layer 5-1> Download IDB Start
20:17:23 858 <Layer 5-1> Download IDB Success
20:17:23 873 <Layer 5-1> Reset Device Start
20:17:24 967 <Layer 5-1> Reset Device Success
20:17:25 003 <Layer 5-1> Wait For Loader Start
20:17:28 417 <Layer 5-1> Wait For Loader Success
20:17:28 433 <Layer 5-1> Test Device Start
20:17:29 478 <Layer 5-1> Test Device Success
20:17:29 509 <Layer 5-1> Download Firmware Start
20:18:24 422 <LAYER 5-1> ERROR:RKA_File_Check-->Memcmp failed,Read(0)
20:18:24 468 <LAYER 5-1> ERROR:DownloadImage-->RKA_File_Check failed(kernel)
20:18:24 500 <Layer 5-1> Download Firmware Fail
20:18:24 531 **********Upgrade Done Success<0> Fail<1> Time<61636>ms**********
Thanks Received: 3169
2012/09/28 - 01:25
Is your tablet a Cube U30GT-H model, not the W model ?
Can you try flashing again, using the Restore button rather than Upgrade ?
dralp
2012/09/28 - 21:20
Thanks for your replie.. my tablet u30gt-h ı solved the problem.. this problem has caused by bad usb cable.. ı used my nokia 5800 s cable, everything is o now.. ıf somebody has seen this problem may be this post solve some problem..
94 Guest(s)
Devices in use: Desktop (86), Phone (8)
atgyuric
BBonch
crispyduck00
asgard2701
Rob_nl
shadowlabs
Topics: 6028
Members: 261274
