problems with cube 30gt
sjr480
2012/09/14 - 20:31
I tried to update and now the screen is white.
the biggest problem is that win 7 cannot find the usb port for me to  use the recover tool. I have tried the reset button, changed usb cables trie the+ and power and still nothing .it is very expensive to send it back.. any ideas???Cry
Thanks Received: 3169
2012/09/15 - 18:45
Which Cube model do you have, which firmware have you tried ? How did you update your tablet before getting the white screen ?
sjr480
2012/09/16 - 01:39
it is u30gt, and it showed updating then went blank, sometimes comes on brick or white after i set the reset button. when i try the restore program it shows but it says the driver  is not available do you know the path ??
olanda1970
2012/09/25 - 21:25
Just replace the (low quality) usb cable with a better one..I had the same problem
78 Guest(s)
Devices in use: Desktop (69), Phone (9)
васа
kindr
TOFIK
brzeg
ruslanrech
SteveBP
Topics: 6010
Members: 260675
