Help!!! I can't put the Cube U30GT into Recovery Mode to flash !
Thanks Received: 268
2013/01/16 - 15:39
Have you tried using another usb cable ?
Reinstall all the drivers ?
Mutts
Netherlands
Forum Posts: 15
2013/01/16 - 16:01
Yes I tried several usb cables.
As for the driver that is the main problem I found  out.
If I install it WinXP will see the U30GT in the device manager.
And I hear it connect to usb, but the rockchip does not see the tab.
So i know it is alive (even though i see the dead android) but atm i cannot get the driver  to work.
I think that is what is blocking a save reflash.
2013/01/16 - 17:29
use only the usb ports from the back, if you have a pc unit
try to remove any other cables that can interfere or create a conflict in the flashing process
last step, use another pc
533online
2013/01/18 - 20:52
First, good USB cable, then plug cable into unpowered, off tablet, start rock chip 1.5 flash utility, then chose update firmware, then hold volume up button on cube and start button cube, then plugin USB cable to PC, device one button in rock chip utility will turn green or gold, then release buttons , then chose recover button in rock chip utility. Wait for utility to verify update, then release USB device in win, unplug cable and boot cube.
The following users say thank you to 533online for this useful post:
rohshall
assusao20
2013/01/22 - 22:01
Use Usb port from the back
Mutts
Netherlands
Forum Posts: 15
2013/01/22 - 23:11
Little update, i found some XP drivers that recongized my U30GT mini under win 7
Now i need to  find  a solution to let windows start the device.
Atm i get the error windows gives when device manager cannot start up a device.
The so called error 10 or code 10 "This device cannot start. (Code 10)"
149 Guest(s)
Devices in use: Desktop (146), Phone (3)
