2013/01/09
Hello, I am new here I bought a new white Cube U30GT-H 16GB from Aliexpress it has JB 4.1.1 v 1.09
The Tablet its good and very fast except the damn wifi I can't connect to the router from a far distance even i have 3 or 2 bar you must stay close to it
I have try 2 routers the same thing if there a wall betwin the tablet and th router the internet it will be unstable sometimes connect and sometimes the wifi start try connecting
so i want to upgrade to new version on Cube website or to the Cube U30GT-H rooted firmware in hereÂ
when i start to try to put the talet into the recovey mode to flash by pressing power and + nothing happen and the pc never reconize a new hardware like all people happen with them when i conect the usb to pc the tablet turing on by her self then I press power and + it will trrning off and nothing happen , and if i let the tablet on in the RKBatchTool (device connected) is give me pink color not green ?!
do i missing somthing ? and what is that problem of wifi ?do you guys have this problem ?!!
please I am going crazy !!
2012/12/21
I would love to know how to do this too.
Tried several times to get my U30GT mini into flash mode.
But it will not work, it iether starts up normally or it stays off.
As for ADB i think these are drivers for USB?
I recongnize it form flashing my HTC Desire it needed ADB drivers because windows did not see my phone.
So if you mean the ABD drivers how will this work if the Tablet will not go into flash mode from the start?
Thnx for the answer
You need first to enable usb debugging, find the drivers
then install android sdk which has included the adb
then use adb with the command adb reboot bootloader
use google to find more info about adb and how to use it
2013/01/09
Thank you for responding
so when I  will use adb with the command adb reboot bootloader ! it will allow me to enter to the flash mode and use RKBatchTool ? or this is devpoped way to flash the tablet ?
i will try this ; now I am downloading the files !
But why people in all the tutorials not talking about this ?
allways just press power buton and + to get into flash mode !!!
i have tried an other cable the same thing
Thank you any way ..
Lets say that this is the last option, and not to many people know about it.
2012/12/21
Did a litte digging in my BM's and found this link http://forum.xda-developers.com/showthread.php?t=1474956
It might help.
2013/01/09
finally i did it work
you must turn the tablet off
connect the cable to the usb port alone without the tablet
then press + then the power button together whenÂ
when you pressing the two buttons connect the micro usb to the tabletÂ
you will hear the sound of new hardware connectingÂ
Release the two butons now..
work on windows xp but on windows 8 does not work for me
2012/12/27
take car now
because it was ok for me like you
i now i have my u30gth 32gb completly freezed
with the android robot red logo repairing
i have dissambly the tablet to get acces to the bridge
to have the blue logo in rockchip tool but
during the restore it fails to start the loader
please help me !!!
2013/01/09
jpenzo said
take car nowbecause it was ok for me like you
please help me !!!
sont update your tablet from the front USB it will not work
update it from the back usb ...
2012/12/21
"assusao20 said
finally i did it work..
work on windows xp but on windows 8 does not work for me"
Yes it seems the Cube drivers do not work well under windows 8
My Tab does go into recovery but it won't show up in the rockchip batch tool.
A quick look at the device manager shows the U30GT driver and the message it does not work properly. Seems for windows 8 you need to disable driver signature
See this topic :http://www.arctablet.com/blog/forum/cube-u30gt/usb-driver-for-windows-8/
2013/01/09
 OK thank you for the information man
2012/12/21
I flashed and successfully updated my CUBE mini to from factory 1.0.3 a rooted 1.0.3 firmware.
I took this route mainly to be sure it would work and it did, although at the end windows XP said the rock batch tool stopped working. The tablet started up correctly and worked.
So I decided to upgrade to the 1.0.5 fw, and there it went wrong, halfway true the update process it all stopped. And now i face the widely now dead android, I can access to recovery menu but that is about all.
Flashing from sd will not work it tells me either that:
Apply update from external storage
E: unknown volume for path []
E: error opening : no such file or directory
install from sdcard completeor
update from rk image
Find and check firmware
E: unknown volume for path [/update. img
E: can't mount /update image
Can not found firmware image or invalid image
update rkimage complete.
I have tried all the fw images from 1.0.3 original to the rooted 1.0.5.
None of those are recognized. I have read on this site (cannot find the topic atm) that someone succeeded in flashing from sd. If this will not work is my only option to open up the tablet? Since the current state it is in Win XP wil not see the tablet, so te adb road is not working either.
Any ideas?
85 Guest(s)
Devices in use: Desktop (73), Phone (11), Tablet (1)
PATRYK-VP
victorialp23
alertscam
aolmail7448
Arc123456789
forty42
