Gamelof tFix - Credit to Christian Troy
Bigben
New Zealand
Forum Posts: 98
Thanks Received: 10
2013/01/04 - 06:21
Hi Admin
This fix is in a lots of U30GT Roms I will post the reference from the Developer
ChristianTroy Gameloft Fix
smali job in telephonymanager.java, games require a reply from getdeviceid
http://dragondevs.com/index.php?/topic/654-rom-project-margarine-for-yuandao-n70-update-1102/page__st__260__p__14809#entry14809
I might be worth including this or looking into it.
On a byte count framework.jar & framework-res.apk are different in these other roms, framework.jar is the file referred to in that forum.
wiiwiiking
2013/04/26 - 06:15
The link is dead.
Bigben
New Zealand
Forum Posts: 98
Thanks Received: 10
2013/04/26 - 10:23
Yes I think the developer has dropped out, it does post a fix for his Rom, as its Rom dependent but gives you the info on how to fix.
The Rom developer has to implement the fix,  I tried it and it did not work, I am now using a Jap Rom that has the fix, nearly all the other Roms out there have this fix and from what I can gather its all ready in the U30GT2
I ave been trying lots of other Roms as my U30GT  is tuning out to be the worse piece of crap I have ever brought, lockups, reboots, USB Mass Storage problems most of the times, but when programs run they run, ok, but to get them to run thats the problem.
Currently Online: edds1
63 Guest(s)
Devices in use: Desktop (55), Phone (9)
hans41
rickybk
soniya07
ironmangitar
