2012/12/04
While trying to upgrade my tablet firmware "cube u30gt mini", something went wrong, now I am stuck with a dead android robot with alert on his chest, however my windows7 is not recognizing my device ever since, I have tried to copy update.img to the sdcard but the device doesn't read it I used everything in the blue menu and I have changed the sdcard, the usb cable, and didn't work, if anyone has any idea that worth trying  please tell, even if it is about opening the device.  Â
I can try to recover your tablet via team viewer, check my signature.
2012/12/04
Dear jpenzo,
First you need to disassemble your device, the video shows you how to disassemble your device, however, it is for the ugt30 10", nevertheless, it is quite the same for the 7"
device:
Second you have to identify the good IC to short circuit the pins 29 30, the link just below shows you everything, please refer to the reply of "paguamop 11-13-2012, 09:13 PM" you will find 2 pics that help you out with that, those are everything you need, short it while connecting it to the pc and turn it on with volume+ pressed and 29 30 shorted, then the pc will recognize the device, then just restore the firmware from an img file.
Hope I helped, with my best regards
57 Guest(s)
wemiy54158
sidor
houssmen
qarolus
dav512
tgergely2012
