2012/12/18
Hello all,
Sorry if I started a new topic, as I did not find the information I need. I just got two new cube mini, for the time being I'm using one of them and the other still in box. I hope if someone could help me, because I never rooted or know how to root a device.
1- Is it normal that my charged power up the cube, I can't turn it off during charging, and when I'm charging it and check the status from the settings menu "About" Battery status is "Not Charging" strange?
2- What are the exact steps do I need to root the device (u30gt-m 1.03) August 20th.
3- What/where the tools do I need to root the device?
Regards,
Fouad Douhan
"Committed to the very best"
1- It's common that the tablet starts when a charger is in, at least most Arnova tablet do it.
I don't have my Cube with me but I think it's the case with that model as well. As for the "Not charging" indication, that's usual, I don't know if it's a system bug in your Android firmware or a faulty charger/socket. Does the charge indication show/hides in the bottom right part of the screen when you plug/remove the plug ?
2- 3- We are working on better documenting the firmware upgrade process and will make proper flashing guides  for Cube devices available soon. In the meantime you should find most answers in the forum topics.
2012/12/18
Hello,1- It's common that the tablet starts when a charger is in, at least most Arnova tablet do it.
I don't have my Cube with me but I think it's the case with that model as well. As for the "Not charging" indication, that's usual, I don't know if it's a system bug in your Android firmware or a faulty charger/socket. Does the charge indication show/hides in the bottom right part of the screen when you plug/remove the plug ? Yes there is the Battery sign and it shows that it's recharging.
Regards,
Fouad Douhan
Currently Online: jorm
84 Guest(s)
Devices in use: Desktop (71), Phone (12), Tablet (2)
zvone256
hoholotus
valentin45200
sacha45200
zeus123
Andrew90
Topics: 6026
Members: 261161
