2012/11/03
I juste tried to update to last version of 1.04. It failed, and I have a android monster with a red exclamation mark out of his belly.
What are my option ? Windows does see U30GT tablet, with a question mark. I cannot load the good driver. Please tell me how to reformat this and load a new ROM. I saw some hardware tutorial to reset the ROM.
Tell me what is the best way to recover from this issue.
Thanks.
The only proper way to fix a bricked device, provided it powers up and get detected is to flash a firmware using Rockchip Batch tool.
2012/11/24
Problem is current state of my tablet now is once you power on , straight away got to recovery mode. not connected to PC. So how to use rock chip batch tool? even can't connect to pc at that stage.
now only option is going through SD, however failed. Anyone knows how to upgrade firmware through SD. (Again I know so far all are using rock chip tool for flashing firmware). I am looking for who are really understand the situation. Anyone can help to wrie batch file, patch file for mini. so that we can upgrade through SD mode.
Thanks in advance
2012/12/01
there is method involving dissasembly of tablet
but I don't have T2-T3 screwdriver, and want to use sd card recovery method
user named "unreal" said that he overwrite firmware succesfully with this method, but I dont know how
2012/12/02
Guys, i don't know it's called bricked or not.
But yesterday i flashed my Cube U30gt-H and it said "Loader Failed" or something And my tablet suddenly rebooted but it went to picture with android and red exclamatory sign pop up from his stomach.
And now, everytime i try to push power button, it always goes to that red exclamatory again. And i don't have any ideas.
Can anyone help me to sole this problem?Â
Thanks before
*sorry for my bad english*
2012/11/24
Can anyone help me to sole this problem?ÂÂ
Thanks before
Same happened to me. Any one can tell me how to fix this problem without diassembling.
2012/11/24
mine is U30GT-M (mini).
What I am facing now is unable to install rkusb driver to my computer. my pc windows 7 32 bit.
since I can't install USB driver, RK tool not recognised my tablet n unable to flash.
Once I switch on I only can see recovery mode (with multiple options)
What I need is any way to flash rom from SD card. Again mine is mini vesion 7 inches.
Please help
2012/11/03
Recovery from sd card won't work. The only way to unbrick your tablet is ti dissassembled it as describe into matheos post.
Once open, you have to short the pins 29-30, then boot your tablet. Once the device will be recognize into windows, (drivers will be installed), stop shorting the 2 pins. Device will now be recognize in RBtools and will be in blue. You can now do a RESTORE with your firmware file. DO NOT DO AN UPGRADE.
My friend did it this way and was able to unbrick his U30GT Mini. He also had to use an older firmware.
2012/12/10
bricked on the first day resurrected on the second, and all I can say is that my problems ended once I replaced my hard drive, install vista enterprise 32bit + drivers for U30GT-H and BANG RK30 Tools is working fine and flashed the tablet with kasty-cube_u30gt_h image, all is well now, very happy with the dam thing actually.
73 Guest(s)
Devices in use: Desktop (66), Phone (5), Tablet (2)
wemiy54158
sidor
houssmen
qarolus
dav512
tgergely2012
