[ ROM ] Cube U30GT-MINI Android 4.1 Jelly Bean custom rooted firmware based on update 1.04
rohshall
46
2013/01/24 - 02:36
I am also trying to boot my device into recovery mode. I searched what superoneclick is:
http://forum.xda-developers.com/showthread.php?t=803682
This link says that superoneclick is for rooting the device and I need to have the adb driver for my device.
My problem is
    > adb devices
does not show up anything
Thanks Received: 264
47
2013/01/24 - 03:19
download the program, open it and you will notive that it has a menu that force installs the adb drivers.
if you don`t have the adb drivers installed, nothing will apear when you issue
adb devices
Gravis
Forum Posts: 15
48
2013/01/24 - 20:17
We've tried by ADB and it's impossible...
49
2013/01/25 - 16:49
Yes, it is strange on this tablet, when you issue adb reboot bootloader in recovery it just reboots.
If someone that was a working tablet can test if the tablet enters in flashing mode when you issue the adb reboot bootloader command will be well to know, to do that you need to enable usb debugging and have a little bit of knowldge on how to use adb and android sdk.
Mutts
Netherlands
Forum Posts: 15
50
2013/07/14 - 19:11
Okay a quick question about the nand shortcircuit.
Iv'e opened up de cube minian
d found the nand contacts,but when i attached the cube to my pc by usb do i need to power up the tab first and then connect the pins? or do i connect the pins and then turn on the tab?
I already tried the fisrt connect usb, turn on tab, connect pin 29 & 30 but i still het into the recovery menu.
An the tab does not reset itself, any thoughts?
Thnx
Dante
51
2013/07/14 - 20:20
 Connect the two pins before the 3-4 second power button alone to start. If using the Rock batch tool it will turn into a blue square, ready for a firmware restore. The original firmware from cube 1.03 works best for this. An easy upgrade option is the supersport 900 version, the flash loader is simple to use Cool.
 On my mini I found the Kasty cube firmwares 104 & 105 Cry halted at the boot loader, which turned on the screen android (needing to reset with the pins over and over again).
 Good luck, and don´t press too hard against the pins in case you damage them.
Mutts
Netherlands
Forum Posts: 15
52
2013/07/15 - 16:34
74 Guest(s)
Devices in use: Desktop (68), Phone (5), Tablet (1)
wheaten156
luislx
algua
Twotrains
alexanddercrb
tsmfallen
