[ ROM ] Cube U30GT-MINI Android 4.1 Jelly Bean custom rooted firmware based on update 1.04
Vince
31
2012/12/13 - 16:28
I would like to add some confidence to people who bricked their U30GT Mini. Mine was bricked and tried the solution of shorting 29-30 pins. Works perfectly!
S1eepy
Forum Posts: 17
32
2012/12/17 - 12:30
There is a new stock fw 1.05 !!!
http://www.51cube.com/ch/DownShow.asp?ID=117
Hope for custom mod from admin asap :)
Thanks Received: 3171
33
2012/12/17 - 12:33
I am working on it, but this update from Cube has only a Chinese keyboard, the non Chinese keyboards are removed, I'll publish the custom firmware as soon as I have a properly fixed that, probably later today.
S1eepy
garctablet
Argentina
34
2012/12/17 - 15:05
After much work, I could upgrade my tablet!. I followed the steps of  Piccolo08.
My previous steps were:
1 - update to version 1.04 (using RKtools) without verifying that Android version of Cube had on the tablet. failed!
2 - use recovery v4 and update to 1.03 from SD card. Success!. Then upgrade to 1.04 (using RKtools). failed!
4 - use Piccolo08 procedure. Success! rooted firmware 1.04 working.
Thank you admin, for video.
35
2012/12/17 - 16:30
Vince
36
2012/12/20 - 06:45
Guys,
How do I backup what I have now on the U30GT Mini before I flashing it to 1.05?
Any recommended steps and tools?
Dante
37
2012/12/29 - 15:06
 Following on from ´piccolo08´s advice, can I directly flash with a rooted firmware like kasty_cube 1.05 (instead of stock 1.3) after having problems with getting the mini into Flash mode (Red exclamation Android always appears when turned on).
 And if possible, can anyone tell me which torx size fits the tiny side screws? its smaller than T4.
 Thanks, and I hope this works. Ta.
 Al.
Thanks Received: 264
38
2012/12/29 - 15:42
You can still get in the flash mode like this if you see the green android
C:\Android\android-sdk\platform-tools>adb devices
List of devices attached
0123456789ABCDEF        recovery
C:\Android\android-sdk\platform-tools>adb reboot bootloader
Then your tablet will reboot in the flashing mode.
Of course you need to install the adb drivers, otherwise it will not work.
Dante
Mutts
Netherlands
Forum Posts: 15
39
2012/12/31 - 15:00
Hi all trying to flash my Mini.
But for some reason i do not get into flash mode.
My mini stats up normaly or it gets into recovery mode.
How can i see if it is in flashmode? Or better how long do i have to hold start + volume up?
And is it wise to flash from 1.03 to 1.05?
Dante
40
2012/12/31 - 18:06
 Thanks globula_neagra
 Can I double check before doing anything. If I use the adb devices application I can recover the cube mini?
 I downloaded the adt-bundle-windows-x86, and found the application. My mini goes from flash screen, green android, then immediately to the red exclamation mark android....  ...is this still possible to recover without opening and doing the 29-30 pin boot? and can I then flash with a rooted kasty 1.05 after?
 Appreciate the extra possibilities all-the-same. Ta.
41
2012/12/31 - 21:48
The adb is a debugging bridge and can help you get the tablet in a recovery state.
From what i noticed till now, the adb is not working in recovery mode, but you can try, if you get a sign from your computer when you connect the tablet having the dead green android, the adb should work.
Of course you need the adb drivers.
rohshall
42
2013/01/01 - 17:41
globula_neagra,
Could you please tell me where I can get the adb driver for Cube U30GTH?
I bricked my tablet while doing firmware upgrade and I am not able to get the device in the recovery mode. I held the volume down + power key till I see the logo and then it just shows the dead Android.
So, I am trying to get it into recovery mode using adb now.
43
2013/01/01 - 18:16
Try use the option from Superoneclick that installs the drivers.
Gravis
Forum Posts: 15
44
2013/01/23 - 23:07
Anyone tried to boot u30gt-m from dead android with red triangle by ADB ? Is it possible?
45
2013/01/24 - 02:17
you can not boot from there, from what i remeber you can not even acces the shell
the only thing that you can do via adb when the device is in recovery, is to re-boot it in the flashing mode so you can use rockchip and flash de device.
49 Guest(s)
Devices in use: Desktop (47), Phone (2)
wheaten156
luislx
algua
Twotrains
alexanddercrb
tsmfallen
