[ ROM ] Cube U30GT-MINI Android 4.1 Jelly Bean custom rooted firmware based on update 1.04
dgn54
2012/11/20 - 21:20
hi
my mini does not open:(
recovery mode and wants to install
the image to the sd card how to throw?
the robot red exclamation
thanks
CloneAid1040
2012/11/21 - 02:24
You must flash the Firmware over the "rockchip batch tool 1.5" on your PC, not over the sd card and Recovery Mode.
The guide to do this is on the first page in this thread.
I'm sorry if my englich is something bad, I'm from Germany
dgn54
2012/11/21 - 07:45
hi
recevory mode
uptade rkimage from /sdcard
invalid image:( error
this is why??
Thanks Received: 3171
2012/11/21 - 10:44
As CloneAid1040 said, you need to use Rockchip Batch Tool to flash the firmware on your tablet, putting the image on the sdcard won't work and may brick your tablet.
dgn54
piccolo08
2012/11/21 - 15:03
It's not for mini. It's for gt u30 gt-w
After you flash a JB 4.1 then you can flash a new image using external cart , but at youre own risk!!!
Can brick youre's tablet.
dgn54
2012/11/21 - 15:57
pc driver does not recognize the
what do I do?
samsung ace 2 usb cable will you?
CloneAid1040
2012/11/21 - 18:54
did you open the tablet and bridged the contacts?
dgn54
2012/11/21 - 19:31
mini.jpgImage Enlarger
I have the sd card and wants to install
tablet here is the error ?
CloneAid1040
2012/11/21 - 22:34
you need to flash over the pc with Rockchip Batch Tool and NOT over the SD card. This video is for the "Cube U30GT-W" and not for the "U30GT-Mini" !!!
Mikky.Cz
2012/12/08 - 17:22
piccolo08 said
After a great battle i revive my mini.
First i reflash an 1.30 immage using recovery(dark blue image) then...
disaster
I try to flash a moddified kasty rom v1.4 rooted who initialed brick my tablet.
Aftee i begun the flash goes wrong the tablet brick another one.
I try to reflash it using recovery...but....no flash no party.
So i come back to v1.3...
It's strange why i'm unable to flash v1.4 ...
How did you reflash it back to 1.3 ? please i have problem just with triangl man and all i want is just go back to 1.3
Thnx
garctablet
Argentina
2012/12/10 - 19:25
The same problem. I update the cube mini U30GT to version 1.4 and... appeared the robot with red triangle!
I tonight proves install the original firmware v 1.3 (mode flash vol+ + pow ) again . Is necesary the shorcut on pins 29-30?
Sorry bad english. I'm from Argentina
CloneAid1040
2012/12/10 - 20:24
Yes, you have to connect the contacts. Otherwise it is not possible. How exactly Piccolo08 has already written. I've followed his instructions and it worked.
The following users say thank you to CloneAid1040 for this useful post:
garctablet
garctablet
Argentina
2012/12/11 - 14:09
From Piccolo08 ...
1) shortcut 29-30 pin on nand flash chip
2) connect the tablet at PC with USB cable and press PWR ON.
3) If all is ok a new driver need to be installed.
4) remove shortcut ( i made it with a screwdriver)
5) .... continue with the following steps
to make the bridge (shortcut).... I can use a thin copper wire and insulating tape adhering to the pins?
(Sorry bad english .. Google translate Embarassed).
2012/12/11 - 14:40
I just want to mention it one more time, but disassembling the tablet and making the shortcut on the flash chip pins shouldn't be necessary if the tablet starts, even with the dead Android logo. From there, it should be still fixable using Rockchip Batch Tool.
The current procedure and documentation should be improved soon, together with a video, it will hopefully help people to flash or unbrick their tablet more easily. The shortcut option is really the last resort, when everything has failed. Here is a demo on a UG802 (RK3066 based MiniPC) it works the same for a tablet, just different points on the motherboard to do the shortcut.
76 Guest(s)
Devices in use: Desktop (72), Phone (3), Tablet (1)
wheaten156
luislx
algua
Twotrains
alexanddercrb
tsmfallen
