[ ROM ] Cube U30GT-MINI Android 4.1 Jelly Bean custom rooted firmware update 1.05 (2012/12/14)
Thanks Received: 268
2013/01/01 - 21:34
1: No, you don`t need to have root
2: This rom should allow you to acces the majority of the apps from google play with some restriction where the apps are specially developed for a particular platform/phone
3:Some that has a cube tablet should answer.
emanunet
emanunet
2013/01/02 - 09:57
I see, thanks.
for example, now I can't download Google Chrome, Google Maps and many more apps... you think this might be resolved?
alnitek
France
2013/01/02 - 12:06
emanunet said
I see, thanks.
I don't remember exactly, but I think chrome is the default bowser for this jelly bean 1.05 ROM.
Google maps has been d/l via google play and works fine and the localisation via wifi is OK
About battery, all I can say is that after some training and calibration the tab lis usable for about 3 hours in low level games like puzzles.
Also, I have used mx player with a 1h30 movie in order to empty the battery while training, and had to launch an other time to finish.
If I remember I was 80% filled before the film and was around 30% after the movie.
The tab shut down by itself at 15%, at this moment I power it up one mode time to draw the last of the battery before pluging  the charger.
Alni
Mutts
Netherlands
Forum Posts: 15
2013/01/02 - 13:44
"Hi,
Yes, I'm using the charger I received with the tab. As I remember it's a 2A one.
I've ordered a Usb to 2.5 jack cable and then I will try some of the chargers to USB I already have.
With 5V 1A out I think the charge will be longer but safer, is'nt it ?
Have a happy new year."
As far as i know the tablet will not charge true USB.
A tried my HTC adapter and tried it on my pc's usb ports.
It did not charge. Let me know if it works.
Happy new year all !
alnitek
France
2013/01/02 - 13:54
Mutts said
"As far as i know the tablet will not charge true USB."
Sure, it will not charge this way....
I don't want to charge with some USB port. (5V-500mA)
I want to use this USB cord with :
1- My car charger wich is delivering 2A and 1A..
2- Some of my AC/DC(USB) converters that are giving 5V 1A or 1,5A
regards,
dawja5215
2013/01/12 - 11:48
Hi.
I'm a happy new U30GT Mini user (aside from the battery life we all know) and have been using this ROM from the second day..It solves many problems but after using this ROM I encountered problem on what I think is an essential part of the features..My MicroSD card seem to be unresponsive or ejected/can't be read..My solution is to unplug and plug it back every time it happens..Anybody has similar issue?
Thanks.Smile
Gravis
Forum Posts: 15
2013/01/12 - 13:08
Hey,
I have a problem with flashing my U30GT-M.
I downloaded Rockchip_Batch_Tool_v1.5 + kasty-cube_u30gt_mini-41-105-rooted
Plug USB and turn on +volume , i've choosed drivers from RBT package and it install RK30 , then i open RBT and it recognize device.
So I choose img and click upgrade.
Tablet reboot and looking for Windows 7 looking for a drivers U30GT-M but can't find...
This is log from RBT:
[CODE]
Loading firmware...
Loading firmware Finished.
Loading firmware...
**********Upgrade Action**********
**********Upgrade Start Total<1>**********
<Layer 1-1-2> Test Device Start
<Layer 1-1-2> Test Device Success
<Layer 1-1-2> Check Chip Start
<Layer 1-1-2> Check Chip Success
<Layer 1-1-2> Get FlashInfo Start
<Layer 1-1-2> Get FlashInfo Success
<Layer 1-1-2> Prepare IDB Start
<Layer 1-1-2> Prepare IDB Success
<Layer 1-1-2> Download IDB Start
<Layer 1-1-2> Download IDB Success
<Layer 1-1-2> Reset Device Start
<Layer 1-1-2> Reset Device Success
<Layer 1-1-2> Wait For Loader Start
<Layer 1-1-2> Wait For Loader Fail
**********Upgrade Done Success<0> Fail<1> Time<32277>ms**********
[/CODE]
For now I cant turn on tablet because it's always turn to flashing mode
Where can i find drivers for U30GT-M to let windows recognize it? Or what should I do now to make tablet back alive.. ?
EDIT: Im using short nokia e52 cable
alnitek
France
2013/01/12 - 13:48
dawja5215 said
Hi.
Thanks.Smile
Like you, I'm using this ROM since the second day I got the tab.
I've plugged a 8Go MicroSD with avi files from this day, and now it's ready everytime I power on the tab.
Alni
Gravis
Forum Posts: 15
2013/01/12 - 13:49
Is here anyone who can help to make back alive my tablet?... please
natxuto
2013/01/12 - 22:39
Hi all.
Can anyone confirm CPU reaching 1.6 Ghz (actual max. frequency) with this ROM?
Supersport's one (based also on stock 1.05) max. frequency is 1.4 Ghz.
Thanks.
dawja5215
2013/01/12 - 23:06
alnitek said
dawja5215 said
Hi.
Thanks.Smile
Alni
Thanks for the response.
It turns unreadable if I watch a video file and it goes to sleep.Restarting is making it worse,the same as force shutdown.I've found some users on the net without the same ROM but they said this is RK30066 chip's fault and the only workaround is to format it to NTFS.Hope that info helps.For now I haven't encountered the same problem but some of my video files can't be read,must have been corrupted when transferring.
jjbosco
2013/01/16 - 03:50
Just flashed,   thanks...
Flashed with usb cord supplied with mini, failed flash confirm at 9%...
Used my galixy s cable, as used to flash other rockchip units, worked greet...
mexifanatic
2013/02/26 - 17:37
hit the upgrade button on rk batch tool 1.5...it totally worked for me. Got a little nervous when I saw a damaged sd card notification after start up. Good thing it gave me the option to reformat. 2 Gigs of app space and finally rooted. Yay. Thanks a lot.
advasa
2013/03/01 - 09:45
After installation Firmware kasty-cube_u30gt_mini-41-105-rooted
I have one truble with com.google.android.gsf.login stop it
crossmariian
2013/03/07 - 14:57
My u30gt mini does not work six guns gameloft, asphalt 7, order and chaos
PLEASE SOMEONE HELP ME
77 Guest(s)
Devices in use: Desktop (70), Phone (7)
jacksonrid
usdown
ibob64
kawi
vetBro
