Just released Cube U30GT-MINI official firmware version 1.05 (2012/12/14) U30GTMINI_v1.05_20121214.zip
Version 1.05 revision history from Cube (translated from Chinese by Google Translate):
1. Solve the crash problem of aging;Â
2. sometimes save bookmarks into the browser screen flicker;Â
3. enter the e-mail will be error phenomenon;Â
4. HDMI output Touch interference.
Android build:Â rk30sdk/rk30sdk/rk30sdk:4.1.1/JRO03H/20121122.205441:eng/release-keys
Linux Kernel:Â Linux version 3.0.8+ (eyes#0001@eyes) (gcc version 4.4.3 (GCC) ) #298 SMP PREEMPT 2012-12-13 14:53:49 4:50
Here is a custom rooted firmware version of the Android 4.1 Jelly Bean based on official version 1.05
Features:
- root with latest SuperSU 0.99 (free version)
- writable /system partition
- update busybox to version 1.20.2-cm9
- included hackerskeyboard (a 5-row keyboard using full PC key layout)  as latest Cube update had regular non Chinese keyboard removed
Rooted custom firmware for the CUBE U30GT-MINI: kasty-cube_u30gt_mini-41-105-rooted.zip
Use Rockchip Batch Tool version 1.5 to flash the firmware, don't flash using the "sdcard" method.
Based on the feedback we have received, the Cube U30GT-MINI seems a bit unpredictable when it comes to firmware updates, flashing sometimes fails without reason. Be sure to use a good quality USB cable when flashing.
S1eepy, Degcorp, dawja5215, Iliak, highfish, refrainer If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
I'd just want to mention that I did test this firmware on a Cube U30GT-MINI and can confirm it works, but other feedback are appreciatedÂ
2012/12/17
Hi everybody,
Just flashed this firmware at noon on my just received U30GT-Mini...
Everythings seems to work, localized in french, using supplied hackers keyboard in 4 rows gingerbread style (it's  Xmas present for a 9 years old girl)
Just vocal search does'nt seems to work, but perhaps the firewall at work does'nt permit the nework traffic for this..
Thanks for the job, because stock firmware (1.04) was barely unusable for occidental people...
Alni
2012/12/11
Hi ,Â
I just updated with 1.05.
Vocal search works .
I do not like the hackers keyboard , is there a normal one ?Â
Also , it is impossible to install chrome with this firmware (android store says it is not compatible with the device), it was working with 1.04 and the chinese 1.05, if you have a solution for this, I take .
Anyway , thanks for the job, I had to downgrade from chinese 1.05 to yours 1.04 to get it work properly.
Seti
2012/12/19
Hi all,
I need a help. I wanted to update my shiru shogun 7 (it is clone of U30GT-mini) but when it wanted to loaded a new loader the program showed a error and on the screen I have Android logo with red triangle with an exclamation mark.
Please help me.
Cheers
edit: in task manager it shows me that I have unkwnown drivers "U30GT-M" maybe someone has this drivers and can send me?
2012/12/21
Hi all i'm new to this forum and rather new to flashing tablets.
I recently came into the possesion of a nice White Cube U30GT mini.
It runs on Android 4.04 and the kernel is:
3.0.8+ eyes#0001@eyes #346Â
How can i find out the firmware or is this the same as build-nummer?
if so it says CUBE U30GT -M v1.03
Can i the just upgrade to 1.05?
thnx in advance for the answer.
2012/09/30
Hallo
Sorry for asking but I am completely unknown to updating and since both my computers are down and need to be replaces this is complete new for me but I kike to have the tablet upgraded ( U30GT-H )
I am willing to pay but simply cannot do this. On my PC's I used Teamviewer and I hope there is a mobile version of this available.
Regards
Pootao
You need a computer to flash this firmware.
Check my signature, and if you need help send me a pm.
i00tosee
2012/12/21
Hi everybody,
I'm happy owner of the U30GT-M flashed with this excellent firmware, but I found it running very hot while charging.
Do you experience the same feeling as me about when charging you U30GT tab ?
regards,
Are you using the stock charger? If so that might be the problem.
I read here and on other website the stock charger isn't the most reliable one.
So you might want to buy a better charger.
2012/12/17
Hi,Â
Yes, I'm using the charger I received with the tab. As I remember it's a 2A one.
I've ordered a Usb to 2.5 jack cable and then I will try some of the chargers to USB I already have.
With 5V 1A out I think the charge will be longer but safer, is'nt it ?
Have a happy new year.
2013/01/01
Hey everybody!
I am also a new owner to a Cube U30GT Mini, and so far my experience was... so so.
I received a 12V charger which totally f**ks with the current in the tablet... it loops the reboot screen when i plug it, it makes the screen flicker when the device is on... I ordered a new 5V 2000am adapter... i really hope this would help with that.
I have a few questions about this new 1.05 ROM, bare with me please, I am a total noob with everything that has to do with rooting, flashing etc.
1. do i need to root the tab before i flash this ROM? if so, how do I do that?
2. will this ROM allow me use Google Play store without having compatibility issues?
3. does it help with battery life (I find this tablet's battery life quite horrible)
Thank you very very much, it's really great to find a forum that supports this tablet...
Emanuel
95 Guest(s)
Devices in use: Desktop (79), Phone (14), Tablet (2)
PATRYK-VP
victorialp23
alertscam
aolmail7448
Arc123456789
forty42
