Here is a rooted custom firmware for the CUBE U30GT-HS tablet based on update 1.01 from Cube released 2013/02/25 (U30GT-HS_v1.01_20130225.rar)Â
This firmware is designed for Cube U30GT-HS model, it is reported to work on recent versions of the Cube U30GT-H but hasn't been extensively tested on all models, use at your own risk !
Build information:
Android 4.1.1 build:Â rk30sdk/rk30sdk/rk30sdk:4.1.1/JRO03H/eng.rjg.20130128.115321:eng/opinions-on-teclast-p90hdst-keys
Linux Kernel:Â Linux version 3.0.8+ (rjg@tchipserver2) (gcc version 4.4.3 (GCC) ) #52 SMP PREEMPT Sat Feb 23 20:06:09 CST 2013
This custom Android 4.1 Jelly Bean firmware is rooted and offers the following features:
- root with latest SuperSU version 1.25 (free version)
- increased space for application (/data partition) to 2 GB
- Google Play Store fixes so more applications are visible/compatible
Rooted custom firmware for the CUBE U30GT-HS: kasty-cube_u30gt_hs-41-101-rooted.zip
Using Rockchip Batch Tool version 1.5 to flash the firmware.
crossh, Kon Dou, BONNYMARBLE, 12inf, yitsea If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2012/10/05
What I can tell so far:
- after WakeUp from sleep, the U30GT-H now immediatly and reliably reconnects Wifi. With the 1.11 firmware, I regularly had to go to the Wifi settings and disable/enable Wifi.
- battery drain seems a little higher
- brightness setting is reversed. Slider full to the right side is the least bright setting.
The tablet is stable so far.
2012/11/21
I have the U30GTH, with 1.11 installed, is that the latest official rom for GT-H?
And is this one 1.01, the latest ROM that is compatible with the GT-H?
DeKoepi mentions it works on the sep 2012 make, How would I find out when my hardware was made, I ordered it in October 2012.
Also, there is the rockchip tool v1.7 out, is this to be used, or 1.5 as mentioned here?
I've always used the wipe option in the tool, and many people long ago were mentioning problems with the upgrade option and all their apps and sdcard data remaining. Is this fixed and solid in the tool v1.7?
thanks.
2013/08/29
I can't install Windows driver for my cube u30gt-hs, i try with:
- win 8 x64
- win 7 x32
- win xp x32
but xp says that drivers are wrong.
I used driver found on Rockchip Batch Tool.zip version 1.5 1.6 and 1.7
Please, help me.
Many thanks
Luca
Currently Online: chloeting2701
72 Guest(s)
Devices in use: Desktop (55), Phone (17), Tablet (1)
kevbez
xxxdddd
xxxddd
Kaydc__
jessicapeterson
Riki111
