2012/10/21
Hello Techies,
I have upgraded my Cube U30GT-H to latest firmware and after that Wifi is not turning on. Its is always showing Wifi turning on since 2 days. Tried different firmwares to solve the issue, but not resolved.
Went through various posts for the same issues in different forums and couldn't find any proper solution.
Did factory reset, returned to original firmware(ICS), tried Evolution 1.3, Budadroid etc... Still not resolved!!
Somebody please help me to fix this issue.
2012/10/17
I've got the same problem. Everything was working fine until, after one of charging, wifi cannot start. "Turning on" still blinking, withount any effect... :/
I tried to upgrade soft to 1.07 version, but it didn't help. I jknow that thin problem i quite popular but I cannot find any ideas how solve the problem.
I read about the U30GT-H loosing Wi-FI on a few forums, but noone seems to have a fix. As mentioned on one post, the strange thing is the Wi-FI support normally comes from a RK903 chipset that also provides Bluetooth... and Bluetooth is working for those having a failing Wi-FI.Â
I'll keep checking others feedback and will update here if I find a solution.
2012/11/08
My tablet worked correctly for 3 months but now, I'm also one with wifi issue. I tried many different Firmware ( i bricked it but were able to fix it with the help I found in an other topic).  The result is the same after all update, the wifi is working until I get it disconnect. Once i'm disconnect, the only way to reactive wifi is to update a new firmware (sometime it restart if I turn off the tablet). I Installed the apps "wifi lock" the wifi worked for 3 days without any prolem. When i taked my tablet out of the range of the wifi, wifi stopped working. Can't reload a firmware everyday...
Any idea?
2013/05/31
anyone have a solution on this? got the same problem guys.....
CubeU30GT2 RK3188
After 1 mounth of use ..... the same problem: Wifi-OFF , i can´t turn it on ¡¡
Nobody knows nothing good for this issue. http://www.htcmania.com/showthread.php?t=620346
This is a video from another guy with cubeU30Gt, but the problem remain:Â
http://www.youtube.com/watch?feature=player_embedded&v=OnBIcZgYNTg
How did you solve ??? what can i do ? i´m very frustated
2012/10/09
I have 2 tablets, 1 does it, other is fine. WiFi fails after sleeping.
Fixed by
Upgrade firmware
When switched on WiFi immediately go to WiFi in settings
3 dots for advanced setting
select keep WiFi on during sleep to always
Requires more charging and shutting down properly but solved WiFi issues for me.
Other tablet, same model, same ROMs doesn't require it
2013/05/31
KenShabby said
I have 2 tablets, 1 does it, other is fine. WiFi fails after sleeping.Â
Fixed by
Upgrade firmware
I´ve done every thing: update Roms, restore Roms, factory Reset, adjust avanced setting .... wifi alwayis turn off. I bought 2mounth ago, through cube-tablet, and i bought 2 years extended waranty.  I´m nearly 25days changing emails with cube-tablet and they say always the same: update, restore, factory reset ... update ... update ... factory reset .  I payed.... but they are laughting of me.
The following users say thank you to unodealmeria for this useful post:
anumrMost Users Ever Online: 749
76 Guest(s)
Devices in use: Desktop (70), Phone (5), Tablet (1)
StatusQ
helloyuen
melcis
nelcis
sophiajohnson87
Brainticket
