[ ROM ] Cube U30GT-H rooted firmware (from official version 1.11 dated 2012/12/31)
Bigben
New Zealand
Forum Posts: 98
Thanks Received: 10
121
2013/07/01 - 06:52
kobrawerde said
At the last firmware caste-cube_u30gt_h-411-111-rooted4.zip
U30GT-H - have a very slow WiFi connection?
With only one to two meters is OK .....
Is this firmware bug or defect of my Cube U30GT-H......
This is a defect of all Cube U30GT. I tried a lot of firmware but wifi connection is always slow.
Bigben
New Zealand
Forum Posts: 98
Thanks Received: 10
122
2013/07/01 - 06:54
The Forum locked up and deleted my reply I will do it again but with better program and cut and past it.
Bigben
New Zealand
Forum Posts: 98
Thanks Received: 10
123
2013/07/01 - 07:21
 >This is a defect of all Cube U30GT. I tried a lot of firmware but wifi connection is always slow.
The early U30GT had a ceramic Antenna that was useless, I have seen a few posts and You Tube stuff on how to fix it, also the soldering on the Antenna cable to the PC board can be bad.
Other things that can affect is the WiFi brand rougher use and the encryption setting should be WPA2 PSK.
Plus the WiFi channel that the router is set for, the US default standard is CH6 but here its CH5, I noticed all my neighbours were on CH6 so set mine for CH1.
I get 4 bands in the next room depending how I hold it, Dlink DIR-655 V2 firmware Rev B US model. its a 2.4Ghz router, also notice that cordless phones can also use 2.4Ghz
Comments about WiFi quality is often mentioned with the type of Firmware ROM use but I don't see many people that confirms this, mind you I did use a ROM that gave better Bars in my other room no matter how it was held.
kobrawerde
124
2013/07/01 - 09:44
Three different firmware upgrade
original /modified
For example, this: http://www.flashmyandroid.com/forum/showthread.php?1572-BudaDroid-0-0-3-JB!-for-U30GT-H
with different settings on the router
it is always the same error !
this is 100% error WiFi antenna
on my smartphone ZTE v970 which was located next to U30GT
the connection was OK !
sorry for my english ....... googel translation
see here:
http://www.flashmyandroid.com/forum/showthread.php?1845-new-wifi-mod-very-simple-with-impressive-results
feature=player_embedded
http://www.flashmyandroid.com/forum/showthread.php?1310-Wi-Fi-Aerial-Modification
psolord
Forum Posts: 19
125
2013/07/07 - 13:18
Hey mr Admin sir!
How's that 4gb app space rom version coming along? :)
Thanks Received: 3169
126
2013/07/07 - 13:32
Hello psolord,
Sorry for the delay, I've been so busy lately, you should have it by tomorrow !
127
2013/07/08 - 15:08
New custom firmware update with 4 GB of storage space for application has been published, see post #1.
This is a minor update, users not interested by the increased storage space do not need to update.
psolord
psolord
Forum Posts: 19
128
2013/07/08 - 18:30
Woohoo!
A beer is flying your way.
Thank you very much! :D
psolord
Forum Posts: 19
129
2013/07/09 - 16:54
Um hello again.
How can I access the recovery menu in this rom?
I tried all combinations of power button + volume buttons, but it does not come up.
I want to flash install an init.d script that helps in youtube buffering.
Thanks.
Ogrim
130
2013/07/25 - 14:55
Just flashed my "U30GT-H" tablet with the custom firmware update with 4 GB of storage space for applications!
Got a Total Quadrant score of 4212 as expected & all seems to work G8 so far!
Unfortunately JB4.2 is not likely to come to this tablet/chipset from the manufacturer...
Thank you for your contribution!
Cheers
sinabehzadi
131
2013/08/06 - 15:16
please help me .
I was upgrading my tablet with Rockchip_Batch_Tool_v1.7 and U30GT-H_V1.11_20121229 official update from cube for u30gt-h . after the show in log : idb download failed , its stop and my tablet turn off . I remove usb cable and try to turn on tablet . but the tablet dont turn on :(
please help me . what I do to turn on tablet ???? :( ((
Thanks Received: 264
132
2013/08/06 - 19:59
Try to put the tablet back in flashing mode and reflash
Also read from here
http://www.arctablet.com/blog/forum/archos-arnova-general/possible-fixes-and-repair-methods-for-your-rockchip-tablet/
kobrawerde
133
2013/08/06 - 21:05
if it BRICK ...:-(   ....... a look here:
http://www.flashmyandroid.com/forum/showthread.php?1483-Unbricking
Sarco
Saint-Jérôme, Québec
134
2013/08/13 - 23:48
I can't update google app, reason wrong package? Anybody with same problem?
ilkertr
135
2013/09/09 - 00:38
same problem cube dead!
please help me .   I was upgrading my tablet with Rockchip_Batch_Tool_v1.7 and U30GT-H_V1.11_20121229 official update from cube for u30gt-h . after the show in log : idb download failed , its stop and my tablet turn off . I remove usb cable and try to turn on tablet . but the tablet dont turn on :(   please help me . what I do to turn on tablet ???? :( ((
123 Guest(s)
Devices in use: Desktop (112), Phone (11)
MOADITH
jomacupi
michaos113
mamago68
peaches51
alejiitoo95
