[ ROM ] Cube U30GT-H rooted firmware (from official version 1.11 dated 2012/12/31)
106
2013/06/15 - 14:24
We don't have a github at the moment and most of our modifications are done at the system/binary level, no source code involved.
Kernel wise, tablets based on Rockchip RK3066 are running on 3.0.8 because the manufacturer has only been deploying that one so far. There is some 3.0.8 kernel source code published for Rockchip devices, also the great guys from Crew RKTablets have a homebrew kernel for the U30GT:
http://crewrktablets.arctablet.com/?p=779
Their github: https://github.com/crewrktablets/rk30_kernel
and a 3.0.36 version for newer devices: https://github.com/crewrktablets/rk3x_kernel_3.0.36
p5yc0
Forum Posts: 13
107
2013/06/15 - 17:15
May I ask how to install the kernel.img file? I cannot seem to find information.
I have your rom installed, the kasty-cube_u30gh_h-41-111-rooted2 version.
Thanks Received: 264
108
2013/06/15 - 23:14
there is no such thing as kernel.img, there is only boot.img which may contain a zimage which is the actual kernel.
on the majority of the rockchip tablets, the kernel and boot.img are stand alone
telbatcra
109
2013/06/16 - 17:06
thanks for the reply.
Is there nay way in the future releases to support external webcams or cameras, or can this already be done?
supermario3
110
2013/06/16 - 18:52
Is it possible to port cyanogenmod on our tablet? There are some roms but they are very old. CM10.1 is near a final release (RC5 on my maguro). Is there a hope you can do "the magic" ?
cucurucu
111
2013/06/17 - 11:21
that will be nice
telbatcra
112
2013/06/18 - 16:23
Is there any way to hide the Youtube Sidebar in landscape mode?  I really don't like it to show all the time...
kobrawerde
113
2013/06/24 - 15:38
thanks for the new firmware for Cube U30GT-H .... you are great!  Embarassed
best regards !
psolord
Forum Posts: 19
114
2013/06/26 - 19:29
Hey guys.
I am planning to do a new firmware update in order to take advantage of the init.d support, so I can use the Youtube buffering fix, which worked like a charm on my PC and android mini PC.
So since I am in the process of doing so, I've been wondering....is there a way to have a 4GB app space? I downloaded a rom for my mini PC that is giving me this capability and found it to be very handy. I sure would like to have the same on my Cube, especially since I have a 32GB model with lots of flash space to spare.
Also, just to be on the safe side, the file on the first post kasty-cube_u30gt_h-411-111-rooted4.zip is the latest June 2013 rom right?
Thanks.
115
2013/06/26 - 20:10
The custom firmware published is based on latest official release (to my knowledge) from Cube dated from end 2012. I rebuilt the custom firmware in June to updates some of my custom parts, but it's still based on the same firmware.
If Cube releases a new update I'll make sure to rebuild the custom firmware with 4 GB space for apps. If that doesn't happen soon, I'll make the change on my existing firmware in a couple of days.
psolord
psolord
Forum Posts: 19
116
2013/06/26 - 20:30
I see.
So if it's a matter of days for the 4GB, I can wait so to avoid the rebuilding of the whole system again.
To be frank, the rom you have provided works great, so since it is based on the official one, maybe Cube believes and rightfully so, that there is no real need for a new one.
Still a great job on your part, as I have stated before quite a few times! :)
Thanks.
kobrawerde
117
2013/06/29 - 22:42
At the last firmware caste-cube_u30gt_h-411-111-rooted4.zip
U30GT-H - have a very slow WiFi connection?
With only one to two meters is OK .....
Is this firmware bug or defect of my Cube U30GT-H......
supermario3
118
2013/06/30 - 10:08
This is a defect of all Cube U30GT. I tried a lot of firmware but wifi connection is always slow.
kobrawerde
119
2013/06/30 - 11:18
You are right ...
I also came to this conclusion
Upgrade the original firmware and it is the same error
slow speed wifi :-(
Ps.
maybe the error is from the antenna wifi inside the tablet
As mobile smartfon ZTE v970 ...and exactly  bad
connector contacts wifi.
Imprecise mounting of the tablet in China ?
regards
kobrawerde
120
2013/06/30 - 13:58
Look at the this forum topic
There is a dangerous  solution  :-)   ........
http://www.arctablet.com/blog/forum/cube-u30gt2/cube-u30gt-2-poor-wifi-signal-how-to-fix-it/
60 Guest(s)
Devices in use: Desktop (54), Phone (4), Tablet (2)
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
callmemax
