[ ROM ] Cube U30GT-H rooted firmware (from official version 1.11 dated 2012/12/31)
psolord
Forum Posts: 19
91
2013/04/05 - 17:01
big thanks
abubin
92
2013/04/18 - 06:09
can I know where to get official 1.11 firmware? I can't find it in cube's website.
I tried to update using kasty firmware but it failed. HELP....
my serial is: U30GT32GB12344368345
Bigben
New Zealand
Forum Posts: 98
Thanks Received: 10
93
2013/04/18 - 09:22
Do easy to ind on the 51cube.com site
http://51cube.com/ch/DownShow.asp?ID=127
You will need a download manager to get it like FDM as the site constantly drops off.
Use a good USB cable not the one that came with the Tablet
Also there is nothing at all wrong with the kasty firmware, follow the correct procedure and use a good USB cable and also fully charge the tablet.
Note: After you flash it will take a long time Mins  to reboot.
abubin
94
2013/04/18 - 12:41
thanks...i manage to find the fault. It's my USB port. I plug it into the back usb port and it works. The front doesn't work. However, strange that it works with other tablets that I have flashed the firmware.
Thanks Received: 264
stefan540
96
2013/04/20 - 13:06
Hello everybody :-)
Yesterday i get my Cube U30GT-H...
now i tried to flash this rom... but... i think i have a little Problem.
At first i had to start the Cube with Volume up and Power Button... but... nothing happens....
i know the Technik from other Android devices... but the Cube will not start...
someone have a idea??
greetings from Germany...
Stefan
PS: sorry.... i doesnt know that when i start it with vol.up und Power... the screen keep Black... ;-)
now i have a new rom at the cube and i am happy....
p5yc0
Forum Posts: 13
97
2013/05/06 - 16:40
For anyone wanting to buy a Cube tablet, make sure you DO NOT buy from cube-tablet.com as their after-sales service is total utter poop.
98
2013/06/02 - 22:33
I have just posted a minor update on the custom firmware with the following:
  • update SuperSU to latest 1.30 (free version)
  • update 2013/06/02: Unix like init.d boot scripts support, more details on init.d scripts here
  • update 2013/06/02: changed permissions on external sdcard to allow write access
See post #1 for details and download link.
Update is probably not required if you don't need these new features.
granny66
telbatcra
99
2013/06/14 - 17:37
Just a follow up on the question I asked in the 1.01 FW thread, since this is the last official fw for the GT-H.
Is this ROM, v1.11, always being updated here, even if cube don't release anything?
There is the rockchip tool v1.7 out, is this to be used, or 1.5 as mentioned here?
I've always used the wipe option in the tool, and many people long ago were mentioning problems with the upgrade option and all their apps and sdcard data remaining. Is this fixed and solid in the tool v1.7?
100
2013/06/14 - 17:51
Rockchip Batch Tool was designed for RK3066 based tablets such as the Cube U30GT models, but version 1.6 or 1.7 should work fine for flashing as well. We always recommend to use Restore button to make sure the tablet gets properly erased before flashing.
As for the custom firmware, there are plans for a major update at the moment, but I'll surely rebuild the custom firmware if Cube ever comes with an update on their device.
telbatcra
101
2013/06/14 - 18:47
Ok, its just that on the download page for 1.5, it says download update 1.7, but if it doesn't improve anything, reliability wise, then using 1.5 should be fine.
So the restore button will erase everything on internal and external sd card? or just internal, so one would need to re-install all apps?
if its just internal, then since you're updating the same FW 1.11, then something like Ti backup should restore everything internal fine?  But for the major update, backup/restore to different FW with TiB isn't recommended?
And since I'm already on 1.11, should I update to the latest upload, or wait for the major update, is it long away?
thanks again!
102
2013/06/14 - 19:27
Flashing with Restore will fully erase the tablet internal storage. Normally the flash process and the formatting process that follows (from the recovery system) do not touch the external sdcard, but it's usually safer to remove the sdcard before flashing.
You should be fine with backup/restoring your apps using Titanium backup, even between different firmware versions. Most Google apps like Gmail, Calendar, Maps, etc store data on the cloud, so it shouldn't be much use to to include them in the backup.
As for the upgrade, it's really your decision, I have no idea if Cube will continue to update their firmware and I can't give any date for my next custom firmware build.
supermario3
103
2013/06/15 - 09:02
Are you planning a new custom firmware build for our u30gt? Cool, coolcoolcool!
A sneak peek on the changelog? :-)
104
2013/06/15 - 13:50
There are a few things in the works such as better Google Play Store support (more apps visible/compatible) and a few kernel modules for wider hardware support. I can't give any date for next custom firmware release as this is a work in progress and I am currently busy with other projects as well.
p5yc0
Forum Posts: 13
105
2013/06/15 - 14:02
Hi admin, Is this work-in-progress somewhere in github? Maybe I can give a hand and provide some changes. I want to make the cube more reliable as it is quite slow even after thorough cleaning and de-bloating. Another question is, why is kernerl 3.0.8 in use instead of 3.4.0 (which should be default of Android 4.1)
Anyway, let me know. Thanks.
Currently Online: yogurt888pl
65 Guest(s)
Devices in use: Desktop (61), Phone (5)
yogurt888pl
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
