[ ROM ] Cube U30GT-H rooted firmware (from official version 1.11 dated 2012/12/31)
tkehlet
61
2013/02/14 - 11:22
I had som problems whit (clock wether widgit) and videoplayer. the widget falling out and the videoplayer dosent work proppely. i tried to start films it`s just turn off. i have another cube running on 4.1.1 v1.10 and this work`s good on my tablet.
xzigen
62
2013/02/16 - 01:53
hi, i have installed this software and all installed perfectly, but i am having a problem with my camera, it will not work e.g with skype or even when trying to open the camera app. i am getting the message "camera has stopped". is it only me or anyone else has this problem, any suggestions? thanks
Bigben
New Zealand
Forum Posts: 98
Thanks Received: 10
63
2013/02/16 - 05:19
I gave up with the Camera long ago and it matches the comments in the reviews as utter crap.
durutti
64
2013/02/16 - 18:52
any page wit instructions?
and how do I find the official?
I am on 1.07 is there any difference on how should I update?
freeguy
65
2013/02/20 - 18:32
thx share , just want it
baszer
66
2013/02/27 - 19:30
I installed the drivers via device manager. But still, I can't get the device connected with the Rockchipbatch tool, what to do now?
see image that if I correctly installed drivers.Untitled-1.jpgImage Enlarger
Thanks Received: 264
67
2013/02/27 - 20:24
use another usb cable, and the ports from the back of the pc unit (native ports)
baszer
baszer
68
2013/02/27 - 20:50
thanks globula_neagra , another usb port did the trick.
But is my device now also rooted? Because when I open titanium backup it still asks for root rights.
freeguy
69
2013/03/12 - 03:30
update SU trytry
freeguy
70
2013/03/12 - 03:38
would like to know anyone with the CELL STANDBY battery drain prolem >.<
battery stats show CELL STANDBY use much battery=.= when the pad power on and idle
just like this >.<
screenshot2012061307254.pngImage Enlarger
icelight7
71
2013/03/29 - 18:02
  Rkandroidtool says: Error: Low Level Format fail.   What im doing wrong? Is perhaps Nand Chip dead? Tried different PC and Usb cable, same failure.
Press restore not upgrade
bomn
72
2013/03/31 - 08:29
Just released: Cube U30GT-H official firmware version 1.11    U30GT-H_V1.11_20121229.zip (2012/12/31)
CUBE_U30GT-H_v1_11.pngImage Enlarger
CUBE_U30GT-H_v1_11_rooted.pngImage Enlarger
Android 4.1.1 build: rk30sdk/rk30sdk/rk30sdk:4.1.1/JRO03H/eng.zhansb.20121128.094056:eng/opinions-on-teclast-p90hdst-keys
Linux Kernel: Linux version 3.0.8+ (zhansb@tchipServer03) (gcc version 4.4.3 (GCC) ) #302 SMP PREEMPT Thu Dec 27 21:02:20 CST 2012
Google Translation from Chinese on Cube version history mentions the following:
1, to optimize the system stability ;
2, to solve the problem of camera Huaping.
Here is our custom rooted firmware version of the Android 4.1 Jelly Bean based on official Cube version 1.11
Features:
- root with latest SuperSU version 0.99 (free version)
- writable /system partition
Rooted custom firmware for the CUBE U30GT-H: kasty-cube_u30gt_h-41-111-rooted2.zip
Using Rockchip Batch Tool version 1.5 to flash the firmware, works only on U30GT-H model.
Please report any problem with this firmware.
DUDE ...
You rock ! Thank you :)
mailman
73
2013/04/02 - 09:35
I got myself a Cube U30GT-H from Etotalk and am un-experiences with Android tablets. Just wanted to ask your advice. The Cube looks decent, but it has some flaws (also compared to my iPad), being:
- Standby time is very short (max. 2 days)
- Wireless connection is lost after waking up from standby
- Chinese apps cannot be removed and some even have malware
- Some apps will not install or function correctly and report an error, saying that an official android version should be installed or something like that
I have no experience with rooting, but am pretty technical when it comes to windows, networking and NAS systems, so should be fine. Would it make sense to root my Cube, looking at the issues above?
Looking at the below picture, what version do you reckon I have? There is too much info for me there, to be able to determine this:
Firmaware versionImage Enlarger
This is the malware app:
Malware appImage Enlarger
Sorry, screenshots are partially in dutch
Thanks Received: 3171
74
2013/04/02 - 09:46
Based on your first screenshot the installed firmware version is 1.10
Flashing a rooted custom firmware will get you a clean system without most of the unnecessary and Chinese apps installed by default; also latest firmware 1.11 may also help with system stability.
p5yc0
Forum Posts: 13
75
2013/04/02 - 09:51
You have the U30GT-H (the good model) with Android version 4.1.1 (Jelly Bean) with Cube firmware version 1.10 (not the latest which is 1.11)
I strongly suggest that you install the rooted firmware based on Cube's version 1.11 firmware from the first post of this topic.
In reply to your questions:
1. I do not notice standby times as I charge every night. Charge lasts all day even in full use.
2. This is an Android option. You can switch it off from the Wi-fi settings.
3. Use rooted firmware since the Chinese apps are in system folders.
4. Use rooted firmware.
It is pretty simple to root, just follow the instructions.
I have 2 Cube tablets and I do not regret having them rooted. The amount of control you have is just 'total' :)
72 Guest(s)
Devices in use: Desktop (62), Phone (10)
swan12
heftpflaster
