[ ROM ] Cube U30GT-H rooted firmware (from official version 1.11 dated 2012/12/31)
mr-scorpio
46
2013/01/28 - 19:43
Hi there,
Does there exist a comparison between firmware versions: 41-110 an this one: 41-111?
I.E. What fixes, enhancements might there be from updating?
Or if you already have: 41-110, is there much point?
lazlo
47
2013/02/06 - 14:20
sakiscube said
Where is official v1.11 firmware ?
The link in 1st post doesn't work.
I have the same problem.link doesn't work.it is possible to post another link who work?
Where is the best version of rooted firmware to install on the tablet?1.10 or 1.11?
Thanks Received: 3177
48
2013/02/06 - 14:33
Usually the more recent versions are better as the manufacturer does fix new bugs each time, so I'd recommend version 1.11
Which link doesn't work for you ? I have no download problem here.
lazlo
49
2013/02/06 - 17:03
I have problems with link about official firmware 1.11.The page can not be open, with firefox and with internet explorer.After flashing, i prefer to have a copy of official firmware if is necessary to restore the tablet.
Bigben
New Zealand
Forum Posts: 98
Thanks Received: 10
50
2013/02/07 - 04:01
Use a download manager like FDM..
Nothing at all wrong with Cubes site..
lazlo
51
2013/02/07 - 08:32
Sorry, i'm not able to download the file.Can you post it on another hosting site?
52
2013/02/07 - 09:27
The stock 1.1 firmware is available here: U30GT-H_V1.11_20121229.zip
lazlo
53
2013/02/07 - 14:16
Thank you very much.
Only a question: it is the same of cube site?the original firmware version 1.11?...because size is different.447 MB on the cube site vs 282 MB on your link.
54
2013/02/07 - 14:25
It should be the same, I normally just download, rename the firmware file to update.img and remove the extra files. Let me know if you have doubts after flashing so I'll download again and double check my file.
quenxer
55
2013/02/10 - 00:26
Rkandroidtool says:
Error: Low Level Format fail.
What im doing wrong? Is perhaps Nand Chip dead? Tried different PC and Usb cable, same failure.
Bigben
New Zealand
Forum Posts: 98
Thanks Received: 10
56
2013/02/10 - 07:13
Try a different Rom file, plenty out there., or the Cube one.
I have not had any problems with this one  or with many others that I have tried..
The following users say thank you to Bigben for this useful post:
quenxer
quenxer
57
2013/02/10 - 23:39
Yes, tried different roms and official cube one, always same error. Tried RKbatchtool, error if tool tries to low level formating nand. What can i do yet?
Update: It works again yupieee. Maskrom Mode and offical Rom helped.
hureya
58
2013/02/13 - 18:45
hi guys!
I'm using google translator, so, sorry if this text is confusing.
I know this site is for advanced users who know how to modify the tablets, but I've tried other sites that could not help me, so here we go:
I have a Cube U30GT-H, version 1.03, Kernel 3.0.8 +, Android 4.0.4.
I wanted to start learning how to use the "root", and I wonder if I install this firmware posted here, he will get the "root"?
How do the installation process, there is a tutorial for beginners?
this is a better way for me?
Thanks for the collaboration of you and I hope you can help me.
fpopic
59
2013/02/13 - 23:30
hi guys,
i want to root my cube u30gt-h
any safe way to do it (i read about many bricks on forum)
pixellegolas
Forum Posts: 18
Thanks Received: 5
60
2013/02/13 - 23:43
Using rkbatchtool you should be able to use it safely. I have updated many times and no problem. If you get a green square and you have downloaded a rom from this site it should be good :)
The following users say thank you to pixellegolas for this useful post:
fpopic
67 Guest(s)
Devices in use: Desktop (58), Phone (8), Tablet (1)
anqilan456
havetoregister
werasler
5256makc
e-victor
vienzo
