| Latest product reviews |
(7 votes) 08:03
OfflineCube U30GT-H
10:29
OfflineCube U30GT-H
Bigben said
As I thought you are not selection the correct driver plus Not installing it the correct way, when you plug the U30GT hoding the Power/+ keys for a few seconds, from the Cube OFF state, in Windows will find a New Device you the point it to the driver for the Win that you are using..IT NOT A ADB DRIVER AT ALL. Plus turn off the USB setting in SETTINGS.
So what you mean is that to root this device the only option is to flash a pre-rooted ROM? I cannot use ADB?
10:30
OfflineCube U30GT-H
14:11
OfflineCube U30GT-H
Flashplayer does not work without manual replacement of it. There seems to be issues with the version admin uses while image building.
Somewhere in this forums is described how to replace. When i remember rigth u need to deletethe flashplayer folder in system/app or data/app ull find the flashplayer folder just in one of the mentioned paths. Just delete it, restart ur device and install flashplayer new.
Greetz
Tom
The following users say thank you to xdagobert117x for this useful post:
faksan3317:56
OfflineCube U30GT-H
01:28
2012/08/26
OfflineNo Archos/Arnova device
You do not use ADB just to flash IMG Roms, Please go read some Flashing info there is nothing at all to do with a Pre-rooted Rom.
22:43
OfflineCube U30GT-H
I have tried this firmware now and can say it's really buggy. Wifi does not work, flashplayer is not installed. In metro when you install new apps they don't show up on "desktop". You have to search for them in the google up to the left. Will revert to an older version for now
The following users say thank you to pixellegolas for this useful post:
faksan33, Geoffp, den19:34
OfflineFor me all works fine. Wifi get 20-30 mbits speed. I have one question, it is possible to modifi this firmware to get bigger scale to change brightness? Because difference betveen 0 and 100 is so small. If you are in the darkness, 0 brightness is so briht, it should be much more darker. Thanks.
22:01
2012/08/26
The U30GT has Auto brightness, ? have you tuned it off.?
23:11
OfflineCube U30GT-H
07:00
OfflineCube U30GT-H
03:00
2012/08/26
09:55
OnlineJMI Pulse 10
vinella said
ive tried multiple times now over days to download this firmware from both sites (mirror) without success.
Gets to 58% or so and stops – NO RESUME SUPPORT is a killer.
Is there somewhere else i can get it ?
You can follow Bigben's suggestion.
As I already mentioned in the forum, I am planning to add resume support in the download section.
We are also thinking about deploying an extra mirror but we need more data to find a good hosting location/peering.
You are (and the other forum members too) are welcome to [[** please register to see this link **]].
Most Users Ever Online: 646
Currently Online: admin, globula_neagra, makingmanrv, willy56, valerunchiks, nasca, gratton20, hashte, Mewantfirmware, Lumen2003, benji059, fr-fr, tommyv, Alban1, alperenc, DayLaNickDeNho, mihajlo.saltirovski, nicco, tornicess, airman, jhvdp, Original, Meewind, stef_2279, niilo, geek, Bernard jackson, xadaya, mangike, sakisaka, Evdok, bunneh, Paparazzo, trapisantander, matjazz, gjeremie, cummingsk, happyjocker59, kalas, kikoman73, giuse66, dante82, Ambrosini, CAHEK1978, safaribob
233 Guest(s)
admin: 3940
globula_neagra: 2029
Guest Posters: 39
Members: 83016
Forums: 132
Topics: 2986
Newest Members: FILOU, ckudb, safaribob, CAHEK1978, wholesaleezuhlseslsok, Ambrosini
Moderators: HaroldG (117), globula_neagra (2029), exelletor (344)
Administrators: admin (3940)
Log In
Register
Arnova and Archos support Forum
