[ ROM ] Cube U30GT-H rooted firmware (from official version 1.11 dated 2012/12/31)
faksan33
2013/01/02 - 16:16
Does flash player work on this rom? On 1.10 it doesn't work. Thanks...
Thanks Received: 3177
2013/01/02 - 19:10
machomen said
Before publishing the firmware, I did test it on a Cube U30GT-H and had no problem.
A low quality USB cable (such as the one that ships with the tablet) may give random flash failures. I wonder why it would do it on our custom firmware and not official Cube's update...
I have uploaded a new update that corrects the icons links on the homescreen, but it's a very minor fix and it's almost identical to the one I published yesterday.
Hummmm... so what this second version changes exactly? what do you mean by "corrects the icons links on the homescreen"? I downloaded version 1 yesterday, flashed it today, made my custom tweaks to system apps etc. etc. just to find out its broken? :( is it something worth updating? Could you please make an update zip to include these changes? I really don't want to flash over again, pretty please :)
Oh and the second thing is the double boot screen... I mean... Why? :D Did you do some changes to the kernel or boot.img other than this screens? Can I flash stock instead? Or could you tell me how to change it to say... this Google logo I made? I would really like to Nexus'fy my device :D Again pretty please :)
The second version (kasty-cube_u30gt_h-41-111-rooted2.zip) just updates the homescreen, removing the unnecessary icons (removed apps) there are no other changes in the boot/kernel/system. If you flashed the first version (kasty-cube_u30gt_h-41-111-rooted.zip) there is absolutely no need to update Wink
We had an online service to change the boot logo a while ago, but it's currently shut down but we should reopen it in the future, probably with some technical info for those willing to change the boot logo themselves :)
whatsthat
2013/01/03 - 03:38
I wont update my cube because 1.10 is the most stable I have ever used. My cube can standby for weeks not drop a single % battery.
p5yc0
Forum Posts: 13
2013/01/03 - 16:10
In my Window 7 Device Manager, I am getting 'Other devices -> U30GT-H'
When I update the drivers using the rockchip usb that came with the 1.5 software, it says that the drivers are not compatible. Are there any newer USB drivers for the U30GT-H ?
I want to root my phone instead of flashing so any help to find the correct USB drivers is appreciated...
Thank you.
machomen
2013/01/03 - 16:22
Could you please post a quick quide on how to do this manualy until the time you reopen the kitchen?(This is kind of annoying, I have to turn my head away everytime I turn my tablet on to not see this... :-))
Or at least make a boot.img with the Google logo I shared a link to? ;-)
wolfanger
2013/01/03 - 17:45
after fixing playstore (editing build.pro and using xml fixes) i can see more apps but many games still crash on start. any advice ?
wolfanger
2013/01/04 - 08:22
Sorry for second post' is it possible to reinstall a system app such as gooogle talk?
sakiscube
Greece
2013/01/04 - 23:08
Where is official v1.11 firmware ?
The link in 1st post doesn't work.
Bigben
New Zealand
Forum Posts: 98
Thanks Received: 10
2013/01/05 - 08:53
Thank you.
The Correct Drivers come with the Rockchip Flash tool, if not just dnload the Chinese Rom as they are in there.
Check you are selecting  the right driver..
Bigben
New Zealand
Forum Posts: 98
Thanks Received: 10
2013/01/05 - 08:59
You need the
ChristianTroy Gameloft Fix
smali job in telephonymanager.java, games require a reply from getdeviceid
Its in the  Tab_Modder  Roms and one other from memory
But directory bind did not work to well with these
Forum link for ChristianTroy
http://dragondevs.com/index.php?/topic/654-rom-project-margarine-for-yuandao-n70-update-1102/page__st__260__p__14809#entry14809
Bigben
New Zealand
Forum Posts: 98
Thanks Received: 10
2013/01/05 - 09:00
Titanium lets you do that..
p5yc0
Forum Posts: 13
2013/01/05 - 14:49
Thank you.
I had already downloaded the 1.10 chinese roms (I already have 1.10 installed) and I found the drivers. The point is that when trying to update drivers (U30GT-H) from device manager, I select the correct drivers for my OS (Win7x64) and it says that no correct drivers are found. I got my cube this January so it could be a very new version. I also tried on another machine with Win7x86 installed and the same problem persists. I really want to root or put a rooted ROM but I'm stuck with Windows driver problems. Anyone else with my problem? See attachment:
Untitled.jpgImage Enlarger
psolord
Forum Posts: 19
2013/01/05 - 19:35
@admin
Big thanks for your continued efforts.
faksan33
2013/01/05 - 23:50
Is there anyone who uses 1.11 to tell about the flash player. Does it works?
Bigben
New Zealand
Forum Posts: 98
Thanks Received: 10
2013/01/06 - 01:17
Thank you.
As I thought you are not selection the correct driver plus Not installing it the  correct way, when you plug the U30GT hoding the Power/+ keys for a few seconds, from the Cube OFF state,  in Windows will find a New Device you the point it to the driver for the Win that you are using..
IT NOT A ADB DRIVER AT ALL.  Plus turn off the USB setting in SETTINGS.
86 Guest(s)
Devices in use: Desktop (82), Phone (4)
e-victor
vienzo
superdavex
giorgioo@freemail.hu
suchitratiwari
mantonero
