[ ROM ] Cube U30GT-H rooted firmware (from official version 1.11 dated 2012/12/31)
jmts_7
136
2013/10/12 - 17:16
Hello! This firmware support spanish language? Thanks
kobrawerde
137
2013/10/13 - 09:11
Yes ......
exactly ...... writes: Espańol (Espańa) / Espańol (Estados Unidos) :-)
hpm76
138
2013/10/22 - 22:37
Hi everyone,
I have been trying this last 4gb versión and it works like a charm except for the bluetooth, which doesnt switch on. Catlog shows a countdown but the device does not seem to respond on time.
Curiously it worked fine until I changed the ROM. Any ideas on how to make it work?
Thanks a lot in advance!
fairiesay
139
2013/11/03 - 11:44
Mr1Paulo said
what is "camera huaping"
Hi and big Thanks for good work. I need the update to this root but a I can not find them. If you can help me?? Thanks and have a good time
fairiesay
140
2013/11/03 - 11:53
whatsthat said
I wont update my cube because 1.10 is the most stable I have ever used. My cube can standby for weeks not drop a single % battery.
I am sorry, but my ask my battery is very bad working!! I am searching for the secon version  " kasty-cube_u30gt_h-41-111-rooted2.zip " perhaps I can solve with my Batteryproblem.
Help, I can not find the download link to second version "kasty-cube_u30gt_h-41-111-rooted2.zip" where is this?
have a good day and sorry for my "netiquette" I have not very much "forum-experience"
rockandroll
141
2013/11/30 - 22:52
Good morning to all U30GT-H users.
I recently installed successfully  kasty-cube_u30gt_h-411-111-rooted4_4gb.zip
first of all, Thanks for all the work made on this firmware it seems to work really good BUT!!
I have a question for Advanced user of this tablet.
I have an ethernet(RJ45) micro usb adpater drived by an ASIX 88772A chipset. http://www.asix.com.tw/products.php?op=pItemdetail&PItemID=86;71;101
I noticed that the adapter working properly 3 min (DHCP). ican browse internet etc... then no more network connection available (Local or Internet). i looked at configuration and IP is still good. if i switch on/off eternet nothing happend. I i unplugg adapter nothing changed. I need to reboot to get access for 3 mon more to internet ...:) Thats uggly.
Is there a mean to get such adapter working. a special driver to add in tablet firmware.
I found such article:
http://forum.xda-developers.com/showthread.php?t=2131825
But i have a very poor level to do that. any clue or other method available for my poor knowledge.
Thx for for your help.
watdub
Dublin, Ireland
142
2013/12/24 - 21:17
I just installed the 411-111-rooted4-4gb image via the Rockchip batch tool v1.7 on a U30GT-H and it went well!
So far, so good:
- It's certainly faster (thank you, thank you).
- all my apps installed from the playstore.
- I don't play games so can't comment on that aspect.
- Wifi and battery seem to be better but time will tell.
Haven't tried hdmi yet but 1 person in this thread said it works so I'm guessing it's ok.
The only minor negative is the boot animation locks/freezes for about 10 seconds at boot-up before it shows the lockscreen.  I almost had a heart attack when I first saw it...
Brilliant job, guys.  Thanks again.
nhatnguyenht
143
2013/12/29 - 16:31
Hi admin!
I don't know why the vesion in tool V1.5 is 4.0.4-- vs the topic ver 4.1.???
THanks
berzan
144
2013/12/30 - 04:57
It's just a typo in the parameter file, the version is actually 4.1.
jemihendri
145
2014/02/05 - 16:44
thank you, just installed this rom.
it's awesome.
my 32 gig sd always get error reading with my previous ROM, and now work perfectly and smooth.
I was panick when installing because it always red/fail when Download IDB process; the problem is in my usb cable.
Thank you very much, everything work perfectly on my cube.
mur10
146
2014/03/06 - 19:18
hi my friends
i have a mediacom 102s2 second version ( cube u30gt-hs),I wonder if can install this rom :
what do you think?
thank you
bye
insuline
147
2014/03/19 - 11:10
I installed this ROM 15 days ago.  Everything was great.  Then, gradually, the battery started to unload much faster than before. Nowthe tablet goes off for no reason while the indicator shows battery charge between 40 and 70%. If I plugged the power back on, it does not display 0 but between 40 and 70%. Is this a battery problem or could it be due to the new ROM?
Thank you very much in advance !!!
Bigben
New Zealand
Forum Posts: 98
Thanks Received: 10
148
2014/05/28 - 06:27
Thought I might try the 4Gb version been using Kasty Cube before, been on the Jap Feriross Rom, but only gives 2Gb but did not try the latest version (0510)
But since fully moving to Win 7  from dual boot, having problems in getting the Cube into Flash mode, came back as unknown device no drivers found also tried the Recovery System 4.1 IMG on SDcard, it did flash the Rom but left all the settings,  I think I was a bit slow in setting the Erase data etc..
But I found this site that has a Rockchip program that will install the USB  drivers for you.
With pictures.
http://www.hotmcu.com/wiki/Flashing_Firmware_Image_Files_Using_The_Rockchip_Tool#Install_driver
Install using RK Driver Assistant tools
http://www.haoyuelectronics.com/service/RK3066/tools/windows/RK_DriverAssitant.zip
Now Windows Auto installed the Rockchip USB drivers, Flashed the Rom with the Rockchip Tool 1.7 all OK now and have the 4Gb system ram.
I don't know if my Cube is buggy but took most of a day to get things into Flash mode, I've flashed many Roms before but never had problems like this.
Does  Kasty Cube 4 has this Game Fix  from my post dated 2013/01/05
ChristianTroy Gameloft Fix
smali job in telephonymanager.java, games require a reply from getdeviceid
Dose any one know if Cube has closed down ?  51cube.com has not been working for a week or so.?
So I hope Directory bind works with the Rom  some don't.
Will give some feed back soon.
Many thanks Admin for your Rom support a mate has just got a Pipo M9 Pro and I suggested that he used your Rom..
Bigben
New Zealand
Forum Posts: 98
Thanks Received: 10
149
2014/05/29 - 02:19
Well directory Blind not working to well you have to do a blind check after every boot..
Admin are you there..??
BIG Problem  4Gb system ram does not showing when looking at Running Apps only shows the basic 1Gb, ?
all other things I have tried show the 4Gb of system ram.
can this be patched.??
In Settings/Apps/Running
WiFi good
Seem to have problems with Titanium Backup, it did not backup the OBB folder or the Dload folder, good job I have backed up the int SD Ram..
Can others check the Mem with Running apps.
Bigben
New Zealand
Forum Posts: 98
Thanks Received: 10
150
2014/05/29 - 02:26
Here is our custom firmware based on latest official Cube U30GT-H firmware version 1.11 released 2012/12/31
U30GT-H_V1.11_20121229.zip
report any problem with this firmware.
Hi Admin
Not getting 4Gb system ram when looking at Running Apps only showing 1Gb, any simple way to fix this, ?see my post on Page 10.
114 Guest(s)
Devices in use: Desktop (100), Phone (13), Tablet (1)
MOADITH
jomacupi
michaos113
mamago68
peaches51
alejiitoo95
