2012/10/28
Hello, I need help,
I tried to install your ROM but it stoppet in the middle, here is the log:
20:05:41 088Â Â Â **********Upgrade Start Total<1>**********
20:05:41 090Â Â Â <Layer 3-1-6> Test Device Start
20:05:41 094Â Â Â <Layer 3-1-6> Test Device Success
20:05:41 099Â Â Â <Layer 3-1-6> Check Chip Start
20:05:41 103Â Â Â <Layer 3-1-6> Check Chip Success
20:05:41 106Â Â Â <Layer 3-1-6> Get FlashInfo Start
20:05:41 108Â Â Â <LAYER 3-1-6> INFO:FlashInfo: 0 0 0 1 0 10 10 18 1E 2 3
20:05:41 110Â Â Â <Layer 3-1-6> Get FlashInfo Success
20:05:41 115Â Â Â <Layer 3-1-6> Prepare IDB Start
20:05:41 117Â Â Â <LAYER 3-1-6> INFO:CS(1)Â Â Â Â Â Â (8192MB)Â Â Â Â Â Â (HYNIX)
20:05:41 118Â Â Â <LAYER 3-1-6> INFO:CS(2)Â Â Â Â Â Â (8192MB)Â Â Â Â Â Â (HYNIX)
20:05:41 128Â Â Â <Layer 3-1-6> Prepare IDB Success
20:05:41 129Â Â Â <Layer 3-1-6> Download IDB Start
20:05:41 599Â Â Â <Layer 3-1-6> Download IDB Success
20:05:41 601Â Â Â <Layer 3-1-6> Reset Device Start
20:05:42 603Â Â Â <Layer 3-1-6> Reset Device Success
20:05:42 604Â Â Â <Layer 3-1-6> Wait For Loader Start
20:06:13 040Â Â Â <Layer 3-1-6> Wait For Loader Fail
20:06:13 042Â Â Â **********Upgrade Done Success<0> Fail<1> Time<31964>ms**********
and now I am not able to run the tablet, there is dead android logo with red triangle on it, when I push volume+ power button I go to Android system recovery but nothing there is runing, when I push "wipe data/factory reset, it went through it and then nothing.
When I put apply update from external storage it asks for package to install
/mnt/external_sd
but it is empty, I tried to make such folder on SD card, and also put it in the top of the SD card but nothing is working ...
when I update rkimage... it write E:failed to mount /mnt/external_sd (invalid argument)
please can you suggest something to me or I can throw away the tablet?
thank you ...
2012/08/26
/mnt/external_sd
thank you ...
What brand of USB cable did you use, did you follow the advice to not use the Cube USB cable.
You have to copy update.img to the root of a Fat32 SD card.
Other than that you have to Reset the Cube by opening up and shorting the Reset pads, because Cube left out the reset Switch.
The following users say thank you to Bigben for this useful post:
petel99
Usually on the rockchip tablets if you see the dead android on the screen, if you connect the tablet to the pc, and install the requiered drivers (use superoneclick for example) and then, use adb and issue :
adb devices
adb reboot bootloader
Your device should get in the flashing mode if you get a responde when you use the adb devices command.
Try to use branded cables from Htc, samsung, lg.
petel99
2012/10/28
So I have tried to install it (after the standard update) also from SD card but it didn't worked ... later in the evening I have got to the flashing mode but didn't find out how the adb commands work out... today evening I will try again - is there any clear manual how to use abd commands?
I used cable which came with my HTC one X (don't think I have better cable home, may be from blackberry hmm)
2012/08/26
Forget about this, there are 3 ways to install a Rom and this is not one of them.
From what I can see the Tablet is not bricked so try Rockchip tool again with a better USB cable.
If you cant get it to work you need to reset the Tablet and that is inside, short out 2 tabs where the reset key should have been fitted.
Or you could try the CWM way and flash it with Infected Rom as it uses a different Rockchip tool.
petel99
I did not said that is a way to install a ROM, i said that it is a way to get in the flashing mode without opening the tablet
This is my Arnova 9G3 in recovery mode(With the dead android and exclamation mark) when i use ADB
List of devices attached
0123456789ABCDEF recovery
C:\Android\android-sdk\platform-tools>adb reboot bootloader
The tablet is now in the flashing mode.
I have used this on several tablets that i flashed remotly, and it worked, based on RK29 and RK30 SOCS
petel99
2012/10/28
nothing from your support helped,
I tried to install it from the sd card, so I formatted it and then run it, it went but after the restart it started but then only white screen appeared ...
So I tried it then from the beginning, I have done it several times with HTC original cable, then with Motorola original cable, then with Nokia original cable and still it stopped at the same time at the beginning ...
But then I tried the cube U30GT cable and what? it worked ... so now I have clean JB on it and it is running great
Thank you for your support and creating this clean version ... thumbs up!
84 Guest(s)
Devices in use: Desktop (72), Phone (10), Tablet (2)
avv2011
leadpan101
jumbo65
kalkpits
m12k
StatusQ
