It should work if the hardware is the same, specifically U30GT-H.
You can give it a try, if you have a Shogun 10 firmware available in case of troubles with Cube custom firmware.
Please keep us informed how it goesÂ
2012/11/29
It should work if the hardware is the same, specifically U30GT-H.You can give it a try, if you have a Shogun 10 firmware available in case of troubles with Cube custom firmware.
I've flashed the firmware successfully (yay!). It seems its a lot faster than my previous one (1.06). But i got message about damaged SD storage (i have Shiru Shogun 10 - 32 GB built in version - no SD card inserted). It says i must format it before using (i have backup on it....) and when im trying to connect the storage to my computer (to copy my backup) it just wont connect as a storage (disks are seen under windows 7 but they not "formatted"). Any tips or did i just loose my backup (nothing ULTRA important tho...). Cheers.
Can you check if your micro SDCard is readable on another device, preferably on a computer using a flash card reader (and not thru the tablet) ?
Well, it's not clear to me how you kept backup data on the internal storage then, as flashing the tablet with Rockchip batch tool erases all data and partitions...
2012/11/28
Bigben said
dikkenurd said
Did not work for me i have a white screen.Ive seen lots of posts regarding this white screen, what did you do wrong.?
In the Android recovery menu 3e i wiped cache and data, because with the Rockchip_Batch_Tool_v1.5 it went wrong my pc did not recognize the my U30GT. Thats how i got to the android recovery menu 3e. After that i copyied the update.img on my 2gb scandisk (FAT32) and choose update rkimamge option. and first time it did not work. but i got a Android recovery menu version 4.1 it looked diffrent.
And after that i tried it again via update rkimage thing, and thats how i got to the white screen.
2012/11/18
Can anyone give me a mirror download link??? I am sick of trying to download from the above link. I have failed consequently for the sixth time... I am trying to download for the past 6 days and it's frustrating!!! Admins or someone can you please provide with a mirror link with a faster download?!!! Thanks in advance
I suppose you are located in Asia right ?
There's no mirror at the moment, but we are thinking about setting one soon for users outside Europe (specially US/Asia).
2012/11/29
Here You go sir:
http://rapidgator.net/file/60772850/kasty-cube_u30gt_h-41-109-rooted.zip.html
http://www.sendspace.com/file/opinions-on-teclast-p90hddlpj
http://speedy.sh/pgaBc/kasty-cube-u30gt-h-41-109-rooted.zip
http://uploading.com/files/get/3af389ec/kasty-cube_u30gt_h-41-109-rooted.zip
No changes has been made to package. Cheers.
To be honest, I don't really appreciate having our firmware work put on these kind of uploading sites.
Our custom firmware has not special signature (in boot image or Android about settings) to keep it as stock as possible, but basically with mirrors there are users downloading our work without knowing where it came from.
Please respect our work and don't put it on upload sites.
We should have a mirror site online soon for non European users.
2012/11/29
To be honest, I don't really appreciate having our firmware work put on these kind of uploading sites.Our custom firmware has not special signature (in boot image or Android about settings) to keep it as stock as possible, but basically with mirrors there are users downloading our work without knowing where it came from.
Ok. Sorry about that - i should ask before i upload it. Do You want me to delete it form those sites ? Just wanted to help poor fela
Currently Online: avv2011
77 Guest(s)
Devices in use: Desktop (63), Phone (14), Tablet (1)
avv2011
leadpan101
jumbo65
kalkpits
m12k
StatusQ
