2012/09/28
fahri said
drguild said
fahri said
Bigben said
fahri said
I can´t turn on my U30GT-H after flashing with ROK Batch Tool. When i wanted to flash the firmware from the first site, came the failure download IDB failed
Since then I can`t turn it on and it is not being recognized by my PC and by my notebook. The display is BLACK
What could be the reason for that?????
Please help
Did you used the supplied USB cable.
Get hold of a copy of 900supersport it has a different flash program that I think can recover from that..
yes i used the supplied cable.
DO NOT! use the supplied cable and chuck it in the bin as mentioned hundreds of times around the net get yourself a proper USB 2 certified cable from a computer store.
As mentioned earlier in the thread I went through 10 or so cables allot were the Chinese low cost usb cables before I got my tablet working properly.
There is a big difference between a crappy cheap stock cable and a proper certified USB cable in how good the data transfer works due to the quality of materials used.
Hi. I would like to correct my answer. The first time I used the cable which was delivered. After I have disassenbled the tablet I used my cable from HTC Titan Phone.
Do you mean the causer was the cable?
No idea but cables can be a massive issue even the cable that came with my device while flashed I had loads of issues with crashing and corruption.
Also cables that come with other devices may be low cost and quality also even from bignames as I know that with cables that came with Samsung 3d glasses which the glasses+ cable were priced at $150 or so so get a proper cable from a shop for one.
As for the tablet if it doesn't turn on even to firmware mode with a proper cable and you have done the reset button on the mainboard etc then you are going to need to send it back for warranty as not even we can magically get it working if you have done all the usual.
2012/08/26
Please help
If you read all the Forums thats a Big No No.!
Use the Motorola cable that I posted about.
2012/09/28
GearChange said
Hi all, I have just ordered a Cube U30GT. how do i tell if it is a H model?
Model number.
It'll start with U30GTH32GB if you have a H 32gb version.
Or It''ll say U30GTW16GB for a W 16gb version.
Pretty easy to tell.
It may be listed the full product model where you go it as they normally give the product codes on the website.
As for my tab T4 was still too big so yes Ill have to say its a T2.
Still awaiting on the guy to give me warranty as he seemed to be saying its all my fault for using a different charger even though I stated the problem did not occur when on a charger and it had been running for a hour or so fine on battery when it happened.
2012/09/28
StevenJDM said
Go to Settings and select About tablet. It'll be under the model number.
I forgot to mention not only can be on the website but its also printed on the back of the tablet where I got my examples from.
Thanks for the tip on the Torx screwdriver size. I have one T2 and one T3 on mailorder since a week or so, waiting to receive them to try on my U30GT-H. Cheers.
2012/09/28
GearChange said
Thanks for the replys, looks like it will be W then as i know its 16gb, so no new firmware for me
My post was just a example at how there labeled as both the 16gb and 32gb versions come in both W and H versions.
The seller has sent warranty details now so I'll be RMA'ing the device after Wednesday.
Admin Ive been meaning to ask how do you cook your roms? as I wouldn't mind just looking at adding stuff to the firmwares etc like apk's before I install your rooted roms.
Also do you have a copy of the MetroUI launcher extracted as that was only in a few versions and no longer updated by them.
Wouldn't mind testing it once I get the tablet back from warrenty.
2012/08/26
2012/10/18
Flashed this rom kasty-cube_u30gt_h-41-107-rooted.zip (directly from sd card)
I had no errors...but when I turn the device on, I see the bootlogo and then this dead lying android boy...
Hope its not bricked???
Just flash it again, don't forget to use a proper USB cable, the ones coming with the Cube tablet are not that good quality.
Also, use Restore button in Rockchip flasher.
130 Guest(s)
Devices in use: Desktop (121), Phone (9)
spiik
nikitamaan
VMILCINOV
