2012/10/03
That
There is a thread here about disassembling the tablet:I haven't done it yet as I am missing the right screwdriver.
is the solution. Now i repaired it yeaaaaHHHHHHHHH
That's great news
You mean the disassembly worked ? which screwdriver have you used ?
fahri If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2012/09/28
That's great news
Uses a T4 hex to get in.
I'm yet to open mine as I want to see what went pop but with a white flash and sudden power off I presume its dead and want to see first what fried.
There are no seals just all screws to get in so no chance of breaking anything if your going to send it back.
2012/10/03
That's great news
Yes T4 and a little (german word=kreuz schraubenzieher).
The following users say thank you to fahri for this useful post:
Zygman If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2012/09/28
aragorn73 said
drguild said
Uses a T4 hex to get in.Where did you buy it ?
Actually its a T4 Torx Star driver the guy used on the video.
I don't have one but a family member does Ill have to borrow I only have down to T5.
You can get them on ebay either single size for like $1 or so or like a full 32 piece Chinese cheap set for $5
This is ebay Australia but use ebay for whatever country your in, if you do decide to get a set.
Better sets go for about $25 au and above. Just remember cheap sets won't last more than a few uses so you may want to invest in quality tools.
Always good to get yourself a full toolset of screwdrivers torx, allan keys, wire cutters etc they come in handy for various pc and other work.
The following users say thank you to drguild for this useful post:
daisab
2012/08/26
fahri said
I can´t turn on my U30GT-H after flashing with ROK Batch Tool. When i wanted to flash the firmware from the first site, came the failure download IDB failed
Since then I can`t turn it on and it is not being recognized by my PC and by my notebook. The display is BLACK
What could be the reason for that?????
Please help
Did you used the supplied USB cable.
Get hold of a copy of 900supersport it has a different flash program that I think can recover from that..
2012/08/26
StevenJDM said
fahri said
my pc does not recognize the tablet anymore. I have also tried to connect with my laptop. But it is like there is no power on the tab.
So i can`t flash it, because it is not recohnized. Nothing happensThat was the problem I had and that is why I said the RK batch tool is too risky because this happened to a lot of people.
You would need to disassemble the tablet and reset it.
Only if you use a Bad USB cable
He could try to see if it will go into the Recovery mode hold On and Vol + buttons for some 15 sec or more
2012/08/26
2012/09/28
Bigben said
aragorn73 said
All the post that I have seen refer to a T2
The guy that made that vid says its a T4 'We used the sku8403 on our website(T4).' and my T5 is just alittle too large when T4 would fit I assume as measurements should be standardised already by the industry so no reason it would be a T2 unless someone is using a star thats undersized..
2012/10/03
Please help
yes i used the supplied cable.
2012/09/28
Please help
DO NOT! use the supplied cable and chuck it in the bin as mentioned hundreds of times around the net get yourself a proper USB 2 certified cable from a computer store.
As mentioned earlier in the thread I went through 10 or so cables allot were the Chinese low cost usb cables before I got my tablet working properly.
There is a big difference between a crappy cheap stock cable and a proper certified USB cable in how good the data transfer works due to the quality of materials used.
2012/10/03
drguild said
Please help
Hi. I would like to correct my answer. The first time I used the cable which was delivered. After I have disassenbled the tablet I used my cable from HTC Titan Phone.
Do you mean the causer was the cable?
126 Guest(s)
Devices in use: Desktop (118), Phone (8)
spiik
nikitamaan
VMILCINOV
