CUBE U30GT-H firmware update 1.07 (2012.09.25) just released
staygold1gr
61
2012/10/01 - 13:54
Can someone please verify if wifi direct is working?
tripodlamp
62
2012/10/02 - 04:06
As mentioned earlier wifi direct does not work
briefer
63
2012/10/02 - 09:34
I am running kasty-cube_u30gt_h-41-107-rooted.zip, and it works great, except when I try connecting using the OTG my USB 2,5" hard drive:
http://wdc.com/en/products/products.aspx?id=470 (the previous model, without USB 3.0).
It worked great with my previous tablet, the U9GT2. It failed with some expecific ROMs, so I know it could be a problem of the ROM.
Any workaround to make it work? or is it a limitation of the hw?
Thank you and kind regards ;)
staygold1gr
64
2012/10/02 - 12:02
Is it showing on the menu but does not work, or it is missing completely? If it is missing does anybody know why?I thought the device does support it
przemron
65
2012/10/03 - 01:15
I need kernel 1,7ghz pls!!!!!!¡!!!!!!!¡!!!!!!!!
drguild
Forum Posts: 46
Thanks Received: 8
66
2012/10/03 - 03:16
I don't think there's a overclocking kernel as Rockchip does not release there base source.
I presume you think you want to overclock the device as the cpu speed is not something that you can really change natually just by software.
Overclocking makes the cpu run faster to what it is not designed to do and can cause instability and a shorter life of your device.
Unless you got cpu speed mixed up with something else which I think has happened as you ! and need seems you do not know much about technology or are a kid etc.
tripodlamp
67
2012/10/03 - 06:56
It is missing completely. I could see it with the stock rom (not sure if it worked) but I am under the impression that it has never worked with any of the JB roms.
I also have a problem with bluetooth. I can't get it to receive files but can get it to send files. Have you got this problem also?
fahri
68
2012/10/03 - 12:01
I can´t turn on my U30GT-H after flashing with ROK Batch Tool. When i wanted to flash the firmware from the first site, came the failure download IDB failed
Since then I can`t turn it on and it is not being recognized by my PC and by my notebook. The display is BLACK
What could be the reason for that?????
Please help
69
2012/10/03 - 12:34
The IDB failed error probably reports a failure of the Flash memory.
Can you try to flash the firmware again ? Can you try with the stock firmware as well ?
fahri
70
2012/10/03 - 12:51
Hello dear admin,
my pc does not recognize the tablet anymore. I have also tried to connect with my laptop. But it is like there is no power on the tab.
So i can`t flash it, because it is not recohnized. Nothing happens
StevenJDM
Forum Posts: 14
71
2012/10/03 - 13:19
That was the problem I had and that is why I said the RK batch tool is too risky because this happened to a lot of people.
You would need to disassemble the tablet and reset it.
72
2012/10/03 - 13:20
Can you let the tablet charge for a while (few hours) and try again with the power charger connected ?
Can you also run RK29update.exe from this package RK_Android_Tool_v1.29.zip, see if the tablet is detected, and try EraseIDB button ?
fahri
73
2012/10/03 - 15:46
No.
A message window appears with "no found device for upgrading"
fahri
74
2012/10/03 - 15:48
Hello Steven. What dou you mean with disassemble and reset.
Could you tell me how to do this?
Here is the Tool LOG:
10:45:18 258    Rockchip Batch Tool v1.5.3.0 start run
        10:50:44 713    Rockchip Batch Tool v1.5.3.0 start run
10:54:06 608    Rockchip Batch Tool v1.5.3.0 start run
10:54:15 640    **********Upgrade Start Total<1>**********
10:54:15 640    <Layer 2-1-6> Test Device Start
10:54:15 656    <Layer 2-1-6> Test Device Success
10:54:15 656    <Layer 2-1-6> Check Chip Start
10:54:15 671    <Layer 2-1-6> Check Chip Success
10:54:15 671    <Layer 2-1-6> Get FlashInfo Start
10:54:15 671    <LAYER 2-1-6> INFO:FlashInfo: 0 0 0 1 0 10 10 18 1E 4 F
10:54:15 671    <Layer 2-1-6> Get FlashInfo Success
10:54:15 687    <Layer 2-1-6> Prepare IDB Start
10:54:15 687    <LAYER 2-1-6> INFO:CS(1)        (8192MB)        (MICRON)
10:54:15 687    <LAYER 2-1-6> INFO:CS(2)        (8192MB)        (MICRON)
10:54:15 687    <LAYER 2-1-6> INFO:CS(3)        (8192MB)        (MICRON)
10:54:15 687    <LAYER 2-1-6> INFO:CS(4)        (8192MB)        (MICRON)
10:54:15 749    <Layer 2-1-6> Prepare IDB Success
10:54:15 749    <Layer 2-1-6> Download IDB Start
10:54:41 084    <LAYER 2-1-6> ERROR:WriteIDBlock-->RKU_WriteSector failed,RetCode(-3)
10:55:05 139    <LAYER 2-1-6> ERROR:WriteIDBlock-->RKU_WriteSector-->RKU_EraseBlock failed,RetCode(-4)
10:55:05 139    <Layer 2-1-6> Download IDB Fail
10:55:29 210    <LAYER 2-1-6> ERROR:FindIDBlock-->RKU_ReadSector failed,RetCode(-3)
10:55:53 265    <LAYER 2-1-6> ERROR:BufferWriteBack-->RKU_EraseBlock failed,Block(5),RetCode(-3)
10:56:17 320    <LAYER 2-1-6> ERROR:BufferWriteBack-->RKU_EraseBlock failed,Block(6),RetCode(-3)
10:56:41 379    <LAYER 2-1-6> ERROR:BufferWriteBack-->RKU_EraseBlock failed,Block(7),RetCode(-3)
10:57:05 422    <LAYER 2-1-6> ERROR:BufferWriteBack-->RKU_EraseBlock failed,Block(8),RetCode(-3)
10:57:29 478    <LAYER 2-1-6> ERROR:BufferWriteBack-->RKU_EraseBlock failed,Block(9),RetCode(-3)
10:57:29 478    <LAYER 2-1-6> ERROR:BufferWriteBack failed
10:57:29 478    **********Upgrade Done Success<0> Fail<1> Time<193831>ms**********
11:13:32 812    Rockchip Batch Tool v1.5.3.0 start run
11:29:59 948    Rockchip Batch Tool v1.5.3.0 start run
11:47:49 062    Rockchip Batch Tool v1.5.3.0 start run
12:43:48 536    Rockchip Batch Tool v1.5.3.0 start run
75
2012/10/03 - 15:53
There is a thread here about disassembling the tablet:
http://www.arctablet.com/blog/forum/cube-u30gt/cube-u30gt-doesnt-start-disassambling-to-unbrick-the-tablet/
I haven't done it yet as I am missing the right screwdriver.
77 Guest(s)
Devices in use: Desktop (72), Phone (5)
