2012/08/26
marko75 said
yes, my additional SD card.
The following error occurred while copying
- Copy of internal SD card to ext. SD card - it caused erroneous files
(copy with ES File Manager and Root)
- AnTuTu benchmark
V1.6 = 7900
V1.7 = 6600
The card problem is a know fault and kill all aps and run Antutu again mine was 7200 went up to 7600, I use to get 8100 with a Russian 1.05 rom.
2012/08/26
Abdullah said
I just received my cube u30gt-h from couple days and updated to 1.07 rooted firmware1- a lot of hangs
2- wifi is not stable
3- browser crash suddenly
4- can't run games
5- speaker suck
6- slow running apps
7- suck cameraI really hate it
I get a few hangs, WiFi no problem, Speaker is a know problem, as so as the Camera all listed in the Forums, l Runs games OK as long as they are for the 400Mali chip will not run on the Tegra chip and dont try Chainfire 3D as it will lock up your tablet.
Did you get one of the early ones with the Bad Antenna ?
2012/08/26
drguild said
4- can't run games
5- speaker suck
What usb cable did you use to update it?
If it was the stock do yourself a favor and get a proper certified microusb to usb cable.
Had the same issues and went through 10+ usb cables before buying a proper cable from the shop and re-flash on a 'restore' which fixed all my issues in crashes etc.
Camera is only 2megapixle so yes not much use but I have a 8 on my phone and a 15 dslr so to me the camera doesn't mean anything.
i used the stock and my Galaxy s2 & Galaxy s3 microUSB cables, same things with all!
Buy a proper certified cable don't use a packaged one with another device.
I went through 10+ different cables (yes you read that right) including 3 cables supplied with Samsung 3d glasses for my tv which were not cheap either.
Before I went and bought a new full set of cables for $70AU and had no issues since.
Also do not use the charger and USB at the same time.
If you still have issues after getting a proper cable then look at your pc how its installed and running then if there's issues and the pc is fine do a warranty return.
But I think for you buying a proper cable and not using one with a device would be your best bet.
If you need a Good cable get this one Motorola SKN6238A came with my phone has a longer uUSB plug and locks in , stacks of hits on Google, but note it should have a white label on the cable as there are fake ones around.
2012/08/26
StevenJDM said
I think the RK Batch Tool is just too risky. Problems will occur if you do not do it 100% perfectly. That's why I asked if a recovery image was flashed with this ROM so that way can flash this without the USB cables or a PC but the im pretty sure it isn't.
rename the update to missing the Quotes "update.img"
4) you will need to save this to an sd card
5) put sd card in tablet
6) Restart and cube will detect the update
Or this way.
4) You will need to copy this to your desktop and rename it update
5) you will need to save this to an sd card
6) put sd card in tablet
7)press and hold the volume up button and power button until you see the logo and let go of both buttons
8) You then will see an android guy with a red ! press and hold the volume up and power and another screen comes up with reboot system now, when you see these you let go. It should happen right away after you do power up and volume
9) Use the volume down button to select update rkimage from/sdcard then click the power button to select it.
10) Then use the volume down button down to wipe data/factory reset click power button to select it. Use volume button to go down to yes- delete all user date click power button to select it
11) reboot system now- click power button to select it
When I tried is it stated my update files was faulty, I use the RK batch tool instead.
I think its called a System 4 update
The following users say thank you to Bigben for this useful post:
unreal
2012/09/27
if I read the thread correct the firmware was removed for a bit before it got uploaded again, does the rooted version offered here isbasedon the second upload, if of course they were any different, also does it haveWi-Fi direct? I am running the cleaned 1.04 version and Wi-Fi direct is not even listed in settings. thank you
Bigben said
This was the old History last week for 1.07Correction WiFi instability and sporadic system hangs.
Now
1, revised issues of aging white screen or panic;
2, optimum WiFi problems sometimes cannot be opened.
Just a quick note, I have finally downloaded the "newer" 1.07 firmware Cube U30GT-H on Cube's website.
I have compared the original 1.07 they made available initially on 09/25 (that seems to be removed now) with the new one 09/28, both firmware files are identical, same MD5: 5d62d98b20502acc519273e2c887073a
lessismore8848 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
staygold1gr said
thank you admin, I won't be able to tell if they are identical but happy to take your word for it. and does WiFi direct work?
I'll check and will let you know, I need to check if I have another Wi-FI Direct device here to test with.
staygold1gr If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2012/09/27
staygold1gr said
thank you admin, I won't be able to tell if they are identical but happy to take your word for it. and does WiFi direct work?I'll check and will let you know, I need to check if I have another Wi-FI Direct device here to test with.
the version I am running 1.04 rooted, has not even have the option in settings
2012/09/27
drguild said
Anyone else have crackling and buzzing etc when using the headphone socket?Noticed it was really bad when trying out splashtop and also does it generally in the OS, really off putting and enough that I don't want to use headphones on low volume due to it.
I feel your pain. I had the same problem. I was using a headphone with 3 bands around the plug (it provides volume control and a hang up switch for the phone). It also had an inline mic (no idea if that part matters). It also made a difference depending on how far in I shoved the plug, although one never wants to force it.l
Anyway, I switched to an old MP3-style earbud with only 2 black bands around the plug and the sound is absolutely acceptable. Not great, but good enough.
2012/09/28
Zarb said
I feel your pain.
Was using some good Sony in ear headphones that cost me $100 originally.
Appears tablet is dead now, was watching as youtube vid and having a look at connecting my xbox 360 wired controller to it and as I was about to put in the usb plug a second time as I tested it just before, It appears to have been touching the casing when screen went off and a white flash occurred somewhere, so this appears a bad design or something somewhere.
Also was on battery and not the power charger which really shouldn't have caused this.
Tablet had about 80-90% battery left also.
2012/08/26
4- can't run games
5- speaker suck
Gameloft games don't run with Jelly Been.
2012/08/26
Well known Fault.
2012/08/26
Now
staygold1gr said
if I read the thread correct the firmware was removed for a bit before it got uploaded again, does the rooted version offered here isbasedon the second upload, if of course they were any different, also does it haveWi-Fi direct? I am running the cleaned 1.04 version and Wi-Fi direct is not even listed in settings. thank youJust a quick note, I have finally downloaded the "newer" 1.07 firmware Cube U30GT-H on Cube's website.
All they did was to change the Fix history, the Screen fix thing was not mentioned in the early release of 1.07
82 Guest(s)
Devices in use: Desktop (77), Phone (5)
