2012/08/26
2012/09/26
I have flashed your CUBE U30GT-H firmware 1.07 rom, things are smooth and flashy but the problem with my 32GB Samsung Class10 micro sd-card has not been fixed yet. Clean formated the card to NTFS and fat32, neither one works, tablet doesn't evern recognize it
Please have a look..
2012/09/28
Abdullah said
I just received my cube u30gt-h from couple days and updated to 1.07 rooted firmware1- a lot of hangs
2- wifi is not stable
3- browser crash suddenly
4- can't run games
5- speaker suck
6- slow running apps
7- suck cameraI really hate it
What usb cable did you use to update it?
If it was the stock do yourself a favor and get a proper certified microusb to usb cable.
Had the same issues and went through 10+ usb cables before buying a proper cable from the shop and re-flash on a 'restore' which fixed all my issues in crashes etc.
Camera is only 2megapixle so yes not much use but I have a 8 on my phone and a 15 dslr so to me the camera doesn't mean anything.
2012/09/26
4- can't run games
5- speaker suck
i used the stock and my Galaxy s2 & Galaxy s3 microUSB cables, same things with all!
2012/09/28
4- can't run games
5- speaker suck
Buy a proper certified cable don't use a packaged one with another device.
I went through 10+ different cables (yes you read that right) including 3 cables supplied with Samsung 3d glasses for my tv which were not cheap either.
Before I went and bought a new full set of cables for $70AU and had no issues since.
Also do not use the charger and USB at the same time.
If you still have issues after getting a proper cable then look at your pc how its installed and running then if there's issues and the pc is fine do a warranty return.
But I think for you buying a proper cable and not using one with a device would be your best bet.
2012/04/10
its so weird reading all of these issues people are having. I updated to this rom (1.07rooted) from the 1.05 900 rooted one and have had no issues (apart from the youtube buffering). sd card reads fine every time, wifi works as it should, no hangs..
I use the lead I got with my HTC oneS, never had a moments bother.
Appreciate the work you do with these roms, keep up the great work.
2012/09/29
I've gotta second/third comments re the usb cable.
I've got 2 cubes, both failed to load the image correctly using RKbatch 1.5. I was using the supplied cable at that time.
Had to pull the cube apart to reset for cube to be seen on usb.
Used my good ol nokia cable and both been working with the rooted 1.7 perfectly ever since.
2012/09/28
StevenJDM said
I think the RK Batch Tool is just too risky. Problems will occur if you do not do it 100% perfectly. That's why I asked if a recovery image was flashed with this ROM so that way can flash this without the USB cables or a PC but the im pretty sure it isn't.
If you put the update.img on the root of a sdcard and put the card in it will flash from what I read.
You might need to enter the inbuilt recovery mode by power and volume to do it but heard reports that it should be automatic.
I haven't tried it and may do on the next version.
The RK batch tool is fine if you have good usb cables as I have found and if a flash fails or has issues just reflash again as I went through like 5 or more bad flashes with 1 finished one to begin with different cables etc before I finally figured out it was cables.
2012/08/26
I fixed mine the other day by hot plugging the card a cheap Adata one
I don't think you need a Class 10 card as I can run a 1080P video with a Class 4 card.
The following users say thank you to Bigben for this useful post:
lessismore8848Most Users Ever Online: 803
55 Guest(s)
Devices in use: Desktop (48), Phone (7)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
