Bigben said
Seems to be Problems with this Rom not showing all my files on the SD card I have 75 APK's but in it only showing 63 APK'sone well know App does not work, the 75 files are via The Cube USB from the PC..??
Flash player not instaled
From what I can see far to many Apps removed that can be useful  Like the Weather thing not there.
It's not easy to please everybody, as part the apps cleaning process, I have just removed the non Google/unnecessary apps (some can be downloaded from Google Play Store) and Chinese apps.
I have renamed (using  ApkRename) the removed APKs from the stock 1.07 firmware and made them available separately.
http://www.arctablet.com/assets/firmware/Cube//Cube_U30GT-H_107_fw_removed_apps.zip
cmiuc, evilonex If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2012/08/26
Seems to be Fixed after running superSU, Settings do show the 2Gb ram but a little slow with Anatutu 7200 I used to get 8100 but a little slow with Anatutu  7200 I used to get 8100 with 1.05 Hacked ROM. but goes up to 7600 if I kill all tasks.
Evo list  2gb in there previous builds but it does not show it in the v1.0.2 that I was using last.
Seems to be little better connecting USB
2012/09/26
tripodlamp said
I can't seem to use wifi direct. Also can't receive files via bluetooth (sending works).Is anyone else having these problems?
Only had the tablet for a short time so I'm not sure these were working before I upgraded.
These problems were reported in the previous JB versions also so its not connected with this rooted version.
The following users say thank you to grzes_r07 for this useful post:
admin, tripodlamp
2012/09/26
External SD card works fine, but I am not able install anything on internal storage. For example when I install Titanium Backup, it won't create TitaniumBackup folder in /mnt/sdcard because of rights probably. I am not able to create this directory either with ASTRO or ES filemanager. I am not able to create it in any other internal storage directory. Also almost all internal storage directories are empty…
Edit: solved. I had to reformat nand flash. There was some problem with it...
2012/08/26
2012/09/28
Cube has pulled the firmware from there page for some reason.
I know companies do that if they find major bugs after release.
I may stay on the cleaned 106 rooted which I just put on until till cube puts out a proper 108 with fixes for the 107 thats been pulled.
Came here searching for the flash apk as I couldn't find it turns out the flashplayer file is missing the .apk extension in /system/app
So now you know and can fix it next build
Also can you keep the removed apps with the rom separately in there own folder inside the rom opposed to a separate download as I had no idea where flash was and searched for 30-50 mins or so for a apk until I found this thread and the other one saying flash was still in the system.
The following users say thank you to drguild for this useful post:
grzes_r07
2012/09/26
There is new version of 1.07: http://www.51cube.net/ch/DownShow.asp?ID=80.
@admin - may I ask you for your new version (cleared and rooted)?
drguild said
Cube has pulled the firmware from there page for some reason.I know companies do that if they find major bugs after release.
It seems to be even worse now, there is a 1.07 version listed with today's date in the update as well as older version 1.03 with today's date. I'm downloading both to see the actual dates in the firmware and will rebuilt a custom firmware if needed.Â
In any case I won't be able to test my firmware as my Cube U30GTH does not start anymore, I suspect the half broken charger fried the tablet  So I won't be without U30GT for probably a few weeks. I am not begging in any way, but I probably won't wait for the RMA and go buy a new device right away if I get some support with donations from you guys (see link at the end of my post).
As for Adobe Flash, it's actually there in my custom firmware, I left it how it was in the original firmware, that is /system/app/flashplayer file. For next update, I'll download latest Flash version and put it properly in /system/app as a regular APK file.
I prefer to keep the removed apps out of the package as there doesn't seem to be much demand for these apps.
2012/08/26
They have only changed the change list ie the updates, nothing about the screen failing before, all it listed was fixec lockups and WiFi fix the other day when I looked.
Flash its dead easy to replace and the one in the system app can be fixed by just adding the APK to the end of the file, or as some one else did copy the thing in the system/app to fix the missing apk.
The best place to get the latest version of Flash is from Adobe
Found the link  the latest is  11.1.115.17  but all the files in it are dated 2009..?
http://helpx.adobe.com/flash-player/kb/archived-flash-player-versions.html
I have rebuilt a firmware using the 11.1.115.17, version I just downloaded from Google Play Store on another tablet.
See here
venz0ja If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2012/09/26
I have played some HD content on Youtube, so far it's better than previous Cube Jelly Bean firmwares (fw 1.06), no buffering problems.Â
Edit: After giving a longer test, it does not seem to be completely fixed. Most Youtube HD videos play fine at the beginning, but some buffering does happen before the end of video.
YOUTUBE  HD FIX after update lattest version on googleplay 4.1.23
no lag, no shortly buffer///
The following users say thank you to venz0ja for this useful post:
daisab
2012/09/28
I have rebuilt a firmware using the 11.1.115.17, version I just downloaded from Google Play Store on another tablet.See here
The flash you put on doesn't work it as flash while shows a image doesn't play properly and just hangs and cant get to the settings also original cube's version actually plays than hangs and seems better on 1.07 than it did on 1.06.
That's because its device specific as I mentioned and one of the reasons adobe dropped support because it needs to be customised properly for each device.
Also its the same version or could be lower than what cube has as version you installed was just (11.1.115) installed and what cube has is '11.1.115.11_120806'
I would suggest keeping the original flash from whatever firmware you clean way but make sure it has the '.apk' extension for the build, as it would also allow users to uninstall and update themselves if they want to take that risk as that does work properly.
As the apk how it was with the .apk extension would work fine as it wasn't reconised without the .apk by android after the flash as I found out.
I had to put titanium backup in and convert it to a user app and uninstall and put the backup I made from 106 on else I couldn't uninstall it cause it was classed as a system app.
I do appreciate the work you do put in, in making a clean rom for us.
admin, aragorn73Thanks for the tips drguild, I'll put back the original Flash from the Cube in apk form for next custom firmware rebuild, scheduled this week-end.
2012/09/28
Thanks for the tips drguild, I'll put back the original Flash from the Cube in apk form for next custom firmware rebuild, scheduled this week-end.Cheers.
I did find a working latest flash that I have installed and using now just after I typed that post when I decided to do alittle look.
https://www.dropbox.com/s/72qy2kbmarchnku/Adobe_Flash_Player_11.1.115.17-android4.0%2B.apk
I noticed some devices have special signatures which could be device specific as there is varying results between device apk's etc so that link is a dropbox to the 11.1.115.17 which works same as stock flash form me.
Version you had may have been latest but its like 5am here so may overlook numbers etc doing quick posts.
So this is a good flash for you to put into the rom just keep it as a user app with the apk extension so we can uninstall reinstall ourselves etc without it being system locked.
If the next build doesn't change much Ill keep on this one till next version.
Looked briefly at custom roms online haven't downloaded any but I mainly just want a clean stock good fast one not a ultimate/modded build with everything preinstalled etc which these are and I'm happy for that.
211 Guest(s)
Devices in use: Desktop (205), Phone (6)
