The Cube U30GT based on the Rockchip RK3066 processor is a really cheap and powerful slate, currently one of the best value for the money tablet, available at a mere $210 USD / €170 / 135 UKP easily imported from China. It offers the following features: Dual Core Arm Cortex A9 RK3066 CPU running at 1.6 GHz, 1 Gb RAM, 10" IPS Capacitive Multi-touch 10 Points (1280x800), Bluetooth, HDMI.
Don't forget to check our Cube firmware page for latest Cube firmware updates |
Cube U30GT-H Android 4.1 Jelly Bean with PIP Video Player
The Cube U30GT-H is one of the first tablets based on Rockchip architecture to offer Android 4.1 Jelly Bean (JB), and a great new Picture in Picture (PIP) feature on the Video Player that let you put the playing video in a resizable and movable window, so you can watch a movie while you continue to use the Android tablet for other things.
Cube U30GT-H custom rooted English firmware Android 4.1 firmware
We have built a custom firmware for the Cube U30GT-H model (H only) which provides full root and default language to English rather than Chinese. This firmware is based on the stock firmware 1.06H…
thor14 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
Custom rooted firmware updated from latest Cube 1.06 firmware, default language set to English, Chinese and unnecessary apps removed.
Download: kasty-cube_u30gt_h-41-03.zip
2012/08/26
Link is Dead any reason. ?
I just had a lockup my fault and I thought I would give this a try did try Evolution JB 1.0.2 and to me its full of Bugs cant rotate the screen for one thing and to many apps removed, not been fully tested before its realest.
If this one has been dropped is there one that works..?
Thanks.
Sorry, the file was renamed to match the firmware version from Cube.
Here is the proper link:
http://www.arctablet.com/assets/firmware/Cube/kasty-cube_u30gt_h-41-106-rooted.zip
You can also find it on the Cube U30GT-H specific post.
2012/09/05
Could you please provide instructions on how to upgrade to this? When I had my first Cube U30GT-H, I tried to upgrade to a cleaner 4.1 JB ROM but I guess I didn't do it correctly and I bricked it. Had to send it back and now I'm waiting for my replacement. I want to do it right this time so this won't have to happen again. Thanks.
2012/08/26
You cant brick them they have built on hardware so it can be recovered.
You need a very good USB cable did you use the Rockchip batch tool, if you have the correct drivers install and the Icon on the left show green and their is No chance at all for the USB to loose connection then select Upgrade Not Recover.
2012/09/05
Yeah the only way to recover it was to take it apart. I could not do that because I did not have the tool so I figured if I can send it back for a new one I might as well do it.
At first I did not use a good USB cable because I didn't know they were weak so maybe that was one of the reasons why it failed when I tried to upgrade. Although it did show green when it was connected on Rockchip Batch Tool. The second thing is I used the front USB port on my computer and not the one on the back of it. After it started failing, I then tried to use my cell phone USB cable, which is a quality USB cable, and that was when I bricked it. Couldn't turn it on or anything. So I sent it back and now I will be receiving the new one in a couple of days.
I did use the Rockchip Batch Tool and downloaded the correct drivers. Well I think they were the correct drivers because the device showed up on my computer and it was working properly. I just hope it won't happen when I try it again that's why I asked for instructions so I could make sure I'm doing it correctly.
2012/08/26
Yes the supplied USB cable has very short plug one that I have from a Motorola phone has a long plug that is hard to pull out
Part No. SKN6238A stack of hits on Google for this.
I mean the Plug itself not the sort cable.
Front Ports back Ports, the only thing I can think about is the back ports are direct to the MoBo but the front ones are via a short cable.
The Tablet is not a USB powered device so I just cant see how that matters, been a Computer/Electronic Eng for some 30 years and build my own computers.
I have flashed mine some 4 times now, 2 due to lockups, I use the Motorola cable, computer is some 5 months old dual boot XP/W7 but use XP most of the time my HP scanner has no WIN 7 support.
Even when my Tablet locked up I could not turn it on at all but Fired up the Rocktool and pressed the Power/Vol+ button plugged the USB cable into the PC until I got the green icon, had to do it a few times.
2012/09/05
Oh I see.
I read somewhere that it was best to do it on the back ports since it is hooked up right from the MoBo but I didn't really think it was a big deal if I used the front ports.
But yeah, before I sent the tablet back, I tried so many times including doing what you mentioned and it still did not want to come on or show up on Rockchip Batch Tool. My PC was Windows 7 as well. Maybe a hardware issue on the tablet occurred right after trying to upgrade again. Not sure.
Could you give me a list of steps on how to exactly upgrade to this? Or give me a link to a tutorial. Thanks!
2012/08/26
2012/08/26
I don't have any sleep mode issue here and it shouldn't be a "feature" of our rooted custom firmware, as it's 99% based on the stock firmware from Cube and does not bring changes in the system files.
If the tablet does not get out of sleep mode, pushing Power button for a long time (something like 10 seconds) should reboot it.
102 Guest(s)
Devices in use: Desktop (75), Phone (27)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
