2012/11/27
Hi.
I U30GT Tablet Cube (Shiru Shogun). After the battery is completely discharged, the tablet is turned off. I plugged it into the charger. Turned on for a few seconds, then shut down again. Then I could not run it. Only after 20 minutes (charger still connected) enabled tablet for 5 seconds. There is only the wallpaper screen (no icons) and the bottom toolbar. The battery icon indicated fully discharge and no charge even though the tablet whole time he was under the charger. I should add that when we have problems and discharge, the tablet was connected to a pen-drive cable fault USB. Since then I can not run the tablet.
Is the fault of the charger, battery, charger or entry software?
54 Guest(s)
Devices in use: Desktop (49), Phone (5)
cutierogue
