Cube U30GT - Digitizer / Touch screen replacement
Fernando74IT
2015/01/13 - 10:38
Hi everyone,
I've got a Cube U30GT (aka in Italy as MEDIACOM SmartPad 102 S2).
Well, few weeks ago digitizer glass was broken and I found a replacement on aliexpress.
On last week I received it and mounted it on the tablet but it doesn't work. The glass was a brand new one, so I guess it should work but with more accuracy i found a difference between the broken one and the new one:
the broken one is a 101050-01A
the new one is a 101075-01A
Googling I arrived on this forum and I read that another user had a similar problem but in that case he had got a U30GT2 and he told that, on that model, the two digitizer were interchangable.
So my questions are:
1) Should the 101075-01A work on my U30GT? (if yes i have to consider that received hardware is broken)
2) If not, is a firmware issue? Can i fix it using one of the firmwares present on this portal? What is the best one?
Thanks for help!
Fernando
56 Guest(s)
Devices in use: Desktop (54), Phone (2)
