Cube mini battery strangeness
pixellegolas
Forum Posts: 18
Thanks Received: 5
2012/11/20 - 13:14
Hi all! I got my cube mini yesterday and worked really well. During the night the battery went to down to zero so today I started charging. Nothing is happening though...
I see this strange phenomenon:
I can start the cube and it says battery 1%. If I plug in the charger the tablet turns itself of and cannot be turned on, only after unplugging the charger. In the charger there is a ticking, like a clock, only when plugged in.
I have a normal cube also and tried that charger, still no change.
I believe there is something going in with the cube mini battery. Is it supposed to act like this?
Thanks!
G B
Forum Posts: 21
Thanks Received: 5
2012/12/09 - 09:06
The same thing happened to me when I was charging my cube. As soon as I pulled the power plug the tablet went off. I thiut my bateery wss gone for sure bt then... i charged it till 80‰ then turned it on and off a few times randomly and then suddenly it started working. I recommend you to give a recharge for 5 to 6 hours before turning on again. Also never let your cube go down to 0% battery. Charge when your cube is down to 15%. Also turn off your cube while charging!!! Hope this helps
71 Guest(s)
Devices in use: Desktop (58), Phone (13)
hans41
rickybk
soniya07
ironmangitar
