2012/11/06
I'm al;so a noob and would really like a step by step guild to updating my tablet without any fancy stuff, just using the manufacturer supplied update.
I've downloaded the update and when I start it its in Chinese which doesn't help me. Can anyone show some English screen shots of what I should be doing and I can work out the Chinese interface from that.
Many thanks if you can.
Well, you could use a firmware such as the one we provide, it's setup in English as default and is cleaned with most Chinese and unnecessary apps removed.Â
If you want to keep your actual firmware, just go in the Apps (top right corner), then choose the Settings icon
From the Settings, click on the "Language & input" in the left part of the screen, it's the icon with an  "A" letter inside.
Finally, click on the first line on the right part to change the language.
2012/11/06
Thanks for the quick reply.
Another silly questions. Do you mean to update it with this firmware kasty-cube_u30gt_h-41-107-rooted.zip
Yes, I mean you can update to our kasty-cube_u30gt_h-41-107-rooted.zip if you are interested in the benefit it brings (cleaned system, more space for apps, root...). If not, you can just keep the default firmware switch to English language.
2012/11/06
I've done what you've said and have gotten a lot further ... thanks.
But when I hit the upgrade button I get an error (see screenshot). I've tried the Cube version and your update.img and both give me the same result.
Any suggestions?
I have the screen on the tablet that says, "USB Connected" and the USB storage is turned 'off' ... if this helps.
76 Guest(s)
Devices in use: Desktop (67), Phone (9)
Lalle
slautqua
romcom
willaimjohn66
ahurtama
DEric
